Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 04-28-2004, 10:19 PM   #1
gwainrig
323I Starting problems
My 323I started acting up today. It was first a short lag between turning key and the car starting. Then when you turned the key, the lights go on and off and the engine will not turn over. the battery's eye is green and the interior lights are burning bright. Any ideas on potential issues?
gwainrig is offline   Reply With Quote
Old 04-29-2004, 12:43 PM   #2
323imankiks
323imankiks's Avatar
did you check the for any fault codes? thats a start. you will need a tool peake.com scan tool sells them if you don't have one. then again how old is your car batterys will last around 4 sometime more years until they start to go.
"What happens here stays here" LAS VEGAS
323imankiks is offline   Reply With Quote
Old 04-30-2004, 12:55 AM   #3
318power
blah
Just because your lights are bright doesn't mean your battery has enough charge to power the starter. dash lights and a starter are like the difference between a remote control and a color TV set. your lights don't go out until the battery is completely drained.
318power is offline   Reply With Quote
