Old 04-23-2004, 05:09 PM
robby6161 robby6161 is offline
Send a message via AIM to robby6161 Send a message via MSN to robby6161
93 Suburban changing a water pump
Does anyone out there know where I can find complete instructions in changing a water pump?
Old 04-24-2004, 05:29 PM
jfmctlaw jfmctlaw is offline
Re: 93 Suburban changing a water pump
Go to your local library. Most of them have a ton of Chilton manuals. Water pumps are not too hard to do. A critical point is to completely clean the old gasket off the engine block surface before you mount the new pump on it.
Old 04-26-2004, 05:54 AM
Thanks jfmctlaw on my way!
Old 04-29-2004, 09:27 AM
Ketch Ketch is offline
I have 99 burb. At 30K miles waterpump started leaking bearing oil through weep hole. Replaced it myself. You didnt say what type of truck this is but two biggest issues to watch for, if this applies to your truck:
1) Had to buy a pulley holding tool for like $30 from autoparts store just to get the pulley off the water pump. These are like giant scissors that hold the smaller bolts while you use a large wrench (like 22mm or larger can't remember) to turn out the shaft nut.
2) Coolant needs to be drained completely out of the engine. You will never get all coolant out unless you undo the coolant drain plugs in bottom of block. The new dexcool needs to be mixed precisely at 50/50 and use a measuring cup. There are lots of threads here about problems with Dexcool when not mixed correctly and/or exposed to air from not being topped up.
