Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-12-2004, 04:23 PM
93bird 93bird is offline
Deep Humming Noise
Hello, I have a 93 V6 Tbird (not SC) and my car is making this loud humming or grinding sound but only when I am driving straight or turning to the right. As soon as I make a left turn the noise goes away until I strigten back out and then it comes back. It does not make a difference how fast I am going but the sound is always there as long as I am moving. It sounds like something is rubbing against the tire, any ideas??????????????
Old 03-12-2004, 11:44 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: Deep Humming Noise
Front or Back?
What side?
Old 03-13-2004, 02:55 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
my thunderbird makes a loud humming noise. I figured, or atleast in my case, that its either the intake vaccum from the silencer being removed, or friction from the pullies.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 03-14-2004, 10:14 PM
Re: Re: Deep Humming Noise
Originally Posted by thunderbird muscle
Front or Back?
What side?
It is happening on the front and I think it is coming from the right but it is hard to tell.
Old 03-16-2004, 10:13 AM
could be any of what camaro said or could be something like a bad tire. It could be a lot of things.
Old 03-16-2004, 07:54 PM
RavenProjecT RavenProjecT is offline
Send a message via AIM to RavenProjecT
i would check the inner fender well shields to see if your tires are rubbing against them, cause that's what it sounds like. if not that, look under your radiator for a fallen plastic shield (to protect rad if you bottom out). ot could easily be something like that. if its more serious, you might need new suspension bushings (found at www.mn12performance.com), or arm assembly, or even a brake caliper (happened to me, but i knew what it was and had similar symptom - a broken bolt). just my 2 cent$
Old 03-17-2004, 03:33 AM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
May need a new hub. Does the sound get louder as you go faster? Raise the front of the vehicle and spin the tire by hand. If it is the hub, you should feel it when you spin it.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 03-21-2004, 11:32 AM
fordforlife's Avatar
fordforlife fordforlife is offline
have u changed the brakes lately? u might have bent the brake shield or put something on wrong?
Old 06-11-2004, 01:46 PM
mickhenny mickhenny is offline
It will be the wheel hubs. I have the same car and had to change both of them within a month
