Old 03-07-2004, 09:24 AM
prussell prussell is offline
1997 2wd Pickup Backfire Problem
I have a 1997 Chevy p/u with 110k miles with a 350 engine. It has begun back firing intermittently while starting. The engine will run rough for 30 - 45 seconds then run normally. When this happens, the check engine light comes on and a P0300 trouble code (random/multiple misfire) is stored. I have checked the plugs and resistance on the plug wires and everything is normal. No other trouble codes show. I'm not quite sure what to check next. Any suggestions would be greatly appreciated. I am concerned about a backfire damaging the catalytic converter.
Regards,
Phil
Old 03-07-2004, 12:41 PM
surgicaltech's Avatar
surgicaltech surgicaltech is offline
Re: 1997 2wd Pickup Backfire Problem
Did you check the cap and rotor??
2wd toyota pickup Goose69 Pick-Up 3 08-26-2009 03:27 PM
1997 2WD Sportage Problem oldmike Sportage 0 09-11-2006 08:28 AM
Acceleration Drop out. 94 2wd pickup 22r takakun General Discussion 1 05-11-2005 02:37 PM
Toyota 83 2wd pickup engine swap drj95018 General Discussion 1 04-04-2005 06:26 PM
1997 2WD Tranny problem MMBS C/K 1 02-22-2004 03:04 PM
