Old 02-05-2004, 03:29 PM
bigfoot2471 bigfoot2471 is offline
opti how hard
i have read a lot on other forums about changing the opti. however i am just wondering what you guys think about it. i wonder how hard it is. and how long it takes a newb to do it. thanks
Old 02-06-2004, 03:35 PM
Old 02-07-2004, 12:26 AM
Zwrangler's Avatar
Zwrangler Zwrangler is offline
hmm, i'm gonna need a reply for this question too. my opticrap just started dying on me last month. i doubt its got another month left in it
93 camaro Z28 R.I.P.
From this......................to this and this
check it out at my website
"Pain heals, chicks dig scars but glory is forever !"
Old 02-07-2004, 12:44 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
couldn't tell ya for sure, but i have an LT that i'm putting in my 92 rs and the optispark was very simple to remove plug wires from the opti (make sure u know the cylinder numbers). take the sensor out of it, unbolt it, take it off, put on the new one, bolt up, plug in, and attach wires. the only problem i see is you may have problems w/ the accessory mounts (hell you might have to take off the accessories to do it) and the crammed space of the 4th gen. eta: what i like to call a day project
Old 02-10-2004, 01:02 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: opti how hard
The optispark is a little tricky the first time you do it in a F-body because of the cramped engine bay with the engine removed its much less tricky, The first thing you should know is that your going to have to remove your waterpump which most likely caused it to go in the first place and you better borrow or buy a impact wrench because the crank pulley has to be removed and prying it in place while your turning the bolts will cause damage, Also its a great idea to change the waterpump at the same time, Its not hard if you know what your in for and plan ahead, Also if you give me your email I will send you step by step directions and the problems you will encounter that manuals won't tell you, Also as for time your going to need 4 full free hours.
B16 Or Zc Engine Is It Hard To Put A Engine In A 1990 Crx --dx-- How Hard CRX-Crooks Let's get Technical! 5 01-25-2004 12:52 AM
Seals on '90 V6 Camry: how many, how much $$, how hard to replace colbydmay Camry/Camry Hybrid/Vista 3 01-14-2004 08:35 PM
How hard was Test Driver 6 for you guys? Psman32@af Test Drive Series 20 03-29-2003 12:46 PM
How hard is this to you guys? Psman32@af Need for Speed Series 7 05-15-2001 12:17 PM
