Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 12-24-2001, 03:50 PM   #1
OffroadX
Send a message via AIM to OffroadX
Thumbs up TJM T17 mounted (6 images, 300k)
:jump:
Brent
OffroadX is offline   Reply With Quote
Old 12-25-2001, 12:26 AM   #2
ScottG
I like it. It is kind of understated-It looks similar to stock, but stronger
ScottG is offline   Reply With Quote
Old 12-25-2001, 07:54 PM   #3
Schludwiller
XTerra Guy
Schludwiller's Avatar
I like it, but miss the tubing around the lights. Without the tubes going into the outer fender metal it sort of looks like your truck is sticking out it's lower lip. I almost wonder if powder coating the same color as the plastic would make it seem more integrated.
I bet after you get a winch in there it'll look badass.
Xterra4x4.com and the Xterra Offroad Webring
Schludwiller is offline   Reply With Quote
Old 12-25-2001, 09:43 PM   #4
OffroadX
I ain't spending any money powdercoating something I intend to use and abuse. Being able to touch it up with some black Rustoleum will be nice...
Brent
Old 12-25-2001, 09:53 PM   #5
rednec
rednec's Avatar
Send a message via ICQ to rednec Send a message via AIM to rednec Send a message via MSN to rednec Send a message via Yahoo to rednec
looks good man... you definately needed one.... your old bumper was beat to hell....
'00 Denim Blue Xterra
3" PM Lift (PM=Poor Man's)
33x12.50x15 Muds
Senior Member of ENCXC
rednec is offline   Reply With Quote
Old 12-25-2001, 10:22 PM   #6
rhombus
rhombus's Avatar
I do think that painting the grille black would make it blend in a bit more on the front (with the bumper and hood visor)
I painted mine and while it is a pain to remove is easy to paint and easy to touch up. It should be easier for you to remove since you do not have the bars and winch in the way.
When I did mine I just used cheap rust paint but did sand off the stock paint to give it something to bite to.
Just a thought...
rhombus
SOXC Member
http://www.soxc.org
rhombus is offline   Reply With Quote
Old 12-26-2001, 12:11 PM   #7
Stormy
Stormy's Avatar
Thumbs up
I like how it doesn't match... It gives it a raw look. Kind of mean looking.
Stormy is offline   Reply With Quote
Old 12-26-2001, 12:30 PM   #8
OffroadX
Hmm, painting the grille isn't a bad idea....
Brent
Old 12-27-2001, 02:46 PM   #9
rrdstarr
rrdstarr's Avatar
Brent does the TJM bolt up like the ARB does in three spots? From the looks of pic 3 it does.
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
rrdstarr is offline   Reply With Quote
Old 12-27-2001, 05:44 PM   #10
OffroadX
The TJM has separate mounting brackets that bolt to the frame horns, and the bumper then bolts to it. The mounting brackets are pretty stout, about 3/16" thick reinforced to about 3/8" at the bottom. The brackets alone weigh about as much as the rest of the bumper! The TJM also uses some reinforcing L-brackets that rest on top of the frame rails and are bolted only to the brackets, and an extra plate behind the two bolts into the frame horn. On each side, 2 bolts go into the factory weld nuts in the frame horns (thankfully mine were intact), and the third goes through the tie-down/tow loop on the frame.
The overall view:
Another view:
Here you can see the double-thickness of the bracket at the bottom where the portion going back to the factory tie-down point joins the rest of the bracket:
Here the extra L-bracket on top of the frame horn is visible:
4 bolts hold the bumper to the bracket:
A view from below, showing the "air dam" right above the L-bracket:
And last a view from the inside of the bumper towards the driver's side mounting bracket. I meant to mount all 4 bolts with the nuts on the outside But, you can see how there is room for adjustment in the holes, especially right above the one I have going through from the outside. Also you can see the air dam again.
Brent
Old 12-27-2001, 08:50 PM   #11
rrdstarr
rrdstarr's Avatar
Thanks
I went over to Voy and found these pics posted there and the answer to my guestion!
V.P. of PNWX
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
