Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 01-07-2004, 03:01 AM
gtfan81 gtfan81 is offline
tapping sound in engine
I had the intake manifold gasket replaced on my 97 4x4 last week,the mechanic said after he got it all put back together he noticed the engine had a loud tapping or clicking sound.He pulled the intake back off to look for something foriegn that may have fallen into it.He still has the truck and says he can't find anything so far.What could this be?It was running great before,it just had a coolant leak.
Old 01-15-2004, 10:16 AM
Fox_Rocks Fox_Rocks is offline
Re: tapping sound in engine
tapping sounds are usually associated with the valve train, either high clearances, or worn parts, or something along that line.hope that helped.
1991 Chevy S-10 Ext. Cab
4X4, 4.3L TBI V6.
-Competition Camshaft, Ported Heads, Bored .40 Over,
Completely Rebuilt (everything), Roller Lifters, K&N Filter,
MSD Wires, Jet Performance Chip, B&M Shift Kit,
AirRaid TBI Spacer, 3:42 Posi Trac, 2" Lift,
American Racing Wheels, BFG All Terrain Tires
Old 02-02-2004, 05:50 PM
Built4cyl Built4cyl is offline
Send a message via AIM to Built4cyl Send a message via Yahoo to Built4cyl
You might have a loose rocker, i've had that problem before, on the 2.5L 4cyl just lock it down it has stop plates so u cant over tighten, otherwise the injectors are pretty loud on those type of engines
Old 02-08-2004, 08:55 PM
Philo Philo is offline
If the mechanic just removed the intake manifold, then I would check each cylinder for something small enough to fall through the intake valve. A washer or small nut could go through. The tapping could be the washer or nut hitting the piston, or being caught between the piston and the head/valve. If it is not a loose valve mechanism, you need to assume the worst - that something got into a cylinder, or is stuck in the valve and the piston is hitting the valve.
Engine rapid loud tapping sound Christophe Salvain Venture 3 01-11-2005 09:48 PM
Tapping sound from 4.3L engine in cold weather Jimba61 Jimmy 1 12-06-2004 08:47 AM
Clicking/Tapping Sound Vs. Engine Speed irontodd Wrangler 0 09-27-2004 12:38 PM
tapping sound rfom engin naturalskillz Neon | Plymouth Neon 4 05-08-2004 11:28 PM
Tapping sound in engine bay area?? Sanchi Corolla/Matrix/Voltz 0 07-09-2003 05:51 PM
