Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-30-2003, 01:25 PM   #1
psikora
misfire after fixing coolant leak
I just replaced a 2 1/2", 3/8" dia. coolant hose under the throttle body. It had a pin hole and was leaking onto the exhaust shroud underneath it and getting all steamy.
After replacing the hose, the car won't start or if it does, it'll only run for a few seconds. It sounds awful - loud knocks. It's as if I unplugged all the spark plug wires and put them back incorrectly.
What I did: removed the tube from the throttle body to the air cleaner and some plugs in the immediate area. They all are plugged back in.
Thought: under the area where the coolant eventually found it's way onto the exhaust is what looks to be an exhaust oxygen sensor. Not sure how coolant could get passed the threads but could that be an issue?
It was running well until the hose replacement. Not sure if all the steam before the last starting could have affected anything. ?????
psikora is offline   Reply With Quote
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 05:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 08:53 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 11:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 05:17 PM
97 LeSabre won't start after fixing coolant in cylinder problem robertdh LeSabre 4 09-25-2007 05:52 PM
