Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 11-05-2003, 12:18 PM
dmorse1978
Guest
Posts: n/a
Programming Remote for 1998 Malibu
ABO1502T
This is how I did it..and it worked! Saved $35!
Look in right side wall of trunk..there's a wire taped to another wire that has a plug on it with two prongs. I used my key, yes, my ignition key to jump the plug..I inserted the key between the two prongs and turned so that the key touched both prongs. My car cycled, unlock, lock, trunk release, unlock, lock, trunk release, horn chirp...while keeping the key in place, push (or have someone else do it) the lock and unlock buttons on your remote at the same time for about 12 seconds..you should hear the car lock/unlock. Remove key from plug. Your remote should now be operable. I only had one remote, so if you have more than one, I'd either try repeating the entire process for each remote, or doing each remote one after the other while keeping the key in the plug. I dunno, but if you figure it out, let me know!
<3 Deborah <3
PS- my ignition key has a rubber head! Don't electrocute yourself!
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 12:28 PM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
Program remote for 1998 Grand Prix help clock11 General Discussion 0 04-28-2005 05:02 PM
programming remote for 1998 S-10 txmusicman49 General Discussion 1 12-24-2004 01:45 AM
Help with programming a keyless remote for 1998 Mitsubishi Montero. THanks bertsee Montero/Shogun/Pajero 0 09-05-2004 03:13 PM
