Old 11-04-2003, 08:20 AM
Mr.Bill Mr.Bill is offline
92 3.1 SE P/S and SES problem
I do not remember what pins I need to jumper to get a code from the computer, any help ?
Also I need to replace my power steering pump and resevoir, the thing it throwing fluid as fast as I put it in. How hard it it to replace, any tips ?
Also the SES light comes on just as the car is warming up, and then the idle slows to around 500-600 and sometimes stalls. I failed a receint emissions test here in Maryland and I feel this my be the culprit.
92 3.1 SE with 167,000 miles.
Thanks,
Bill
Old 11-06-2003, 09:18 AM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: 92 3.1 SE P/S and SES problem
I'm not sure about getting the code out. If it failed the emissions test, then it is most likely a problem with your EGR valve or catalytic converter...both are expensive items. There is an easy way to eliminate the cat. Replace it with a straight "test" pipe and see if the SES light goes away.
As far as the PS issue, it is MOST likely the pump seal. I've replaced that in EVERY W-body car I've owned so far. The seal is cheap...$10 from Napa, but the puller to remove the pulley is $50.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 11-07-2003, 12:51 PM
Thanks for the reply, I just went ahead and bought me one of those book for DIY'ers
and the code was easy to get, just jumper the A and B pins with a paper clip (WITH THE KEY ON AND ENGINE NOT RUNNING). and the SES light will blink out the stored codes.
And in my case it was the AIT sensor, and lucky me all that was wrong was the darn thing was not hooked up !!, man I was pissed my son traded me this car for a saturn I had (with less miles). And his G/f's father worked on it all the time and I guess he left this unhooked for some reason. So I will have it re-tested to see if that fixed it.
Runing great now and I found a P/S pump at a local auto yard for $35.00 so all is good .
Old 11-10-2003, 07:46 AM
for those following this thread,
After simply hooking up that AIT sensor, I had the car rechecked Saturday. AND it passed
And on Saturday I replace the power steering pump, and filled and bled the lines. But to my dismay, when backing the car down the driveway there was that darn trail of steering fluid following the car. Looking under I saw a steady drip of fluid off the crossmember.
I guess the leak was in the lines somewhere or down at the steering mechanism. NOT the pump itself.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
