Old 10-05-2003, 09:39 PM
mtdxx mtdxx is offline
valve tap
I've got a 94 civic DX with 158K
I've got an intermitent valve tap type sound all the time, but it is especially bad when it is cold. I am hoping there is excessive valve lash against the rocker arms, if it is not this, are there any other things you guys may have come across in this situation?
Broken valve spring maybe? What do you guys think?
Old 10-05-2003, 09:45 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
i have a 94 ex with 165,000 on it that has a pretty decent amount of valve train noise as well... mainly at cold starts are you said
I've only had this car since July and got it from a dealerships crap auction... its seen better days but I have brought it somewhat back to life. if the valves have adjustment or something like that that would be great. i know, i need to get the shop manual for it but i havent had a chance... as of right now i don't even have the owners manual!
LS1 RX-7 Zoom Zoom
Old 10-05-2003, 09:50 PM
i've never done a valve adjust ment before, but it seems simple enough. I plan on doing my timing belt this week, so while I have the valve cover off I am going to check this. I got to get the spec on that clearance though. I checked mitchells and did not find it, I have to check alldata at work for it. I need to get my hands on a factory manual. i've been to the website, but never seem to have time to download it.
Old 10-06-2003, 09:49 PM
Valve tap/tick solved!!! the valve adjustment is done, it was rather easy. I recommend doing it.
Old 10-06-2003, 11:54 PM
BullShifter's Avatar
Re: valve tap
Yep that usually would fix it. While the valve cover most mechanics would have noticed any other problem that could cause a tick. Honda 4-banger should have the valves adjusted atleast every 30K miles. Always adjust when the engine is COLD, not even slightly warm. Make sure to replace the valve cover gasket & plug grommets. Honda's use solid lifters, reason for adjustments.
Your valve clearance should be listed on a sticker under-hood. Here's a link for the process.
http://www.binghamtonlife.com/manual...es/91-6-30.jpg
http://www.binghamtonlife.com/manual...es/91-6-31.jpg
Alldata is a good source, but not as good as the factory repair manual - paper edition.
Old 10-07-2003, 09:09 PM
yep, it was under the hood. Thanks for posting that link. Can I get all the pages of this manual at this website?
Old 10-07-2003, 10:44 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
i wish it were that easy on the B series. They are really deep down in there to where as the D series are really accesible.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 10-08-2003, 03:06 AM
Re: valve tap
The manual is for a 1991 CRX -
http://www.binghamtonlife.com/manual/2gsm/default.htm
valve tapping when engine is cold steveandles Corolla/Matrix/Voltz 4 07-07-2004 10:50 AM
1998 Stratus Valve Tap Kirk1234 Stratus 1 03-24-2004 08:11 PM
Valve Tap Kirk1234 Engineering/ Technical 1 03-11-2004 08:22 AM
Valve Taps! BOB9273 Blazer 0 02-17-2004 09:14 PM
