Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-03-2003, 12:28 AM
asimdcool asimdcool is offline
Send a message via AIM to asimdcool Send a message via MSN to asimdcool
Question check engine light and knocking
Hey guyz, if anybody could help. I have 96 Maxima and recently check engine light turned on and is not turning off. Also sometimes the car keeps knocking or miss fires, there is loss of power or the car shakes when pressing gas and also check engine light flashes. Feels like the engine is breaking down while pressing gas. Also at red light or stop sign, the car is shaking. Sometimes i dont have this problem and car runs fine.
Any suggestions.. I will try to reset the OCM but i am not sure this will help.
Old 09-03-2003, 08:21 AM
maximaseefu's Avatar
maximaseefu maximaseefu is offline
Send a message via ICQ to maximaseefu Send a message via AIM to maximaseefu
check your ECU codes
Old 11-23-2003, 10:38 AM
tkiser tkiser is offline
I am having the same problem
Hello,
I have a 1995 Nissan Maxima and my car has the same problem. It started 3 days ago with the shaking and feeling like it was going to stall when stopped. I also have major loss of power and it continues to missfire as I accelerate. After three days of this my check engine light is now on and will not go off?
Where you able to solve your problem? Does anyone have any suggestions?
Thanks in advance!
Old 11-23-2003, 03:46 PM
carabuser's Avatar
carabuser carabuser is offline
Re: check engine light and knocking
Check the codes, check/change you plugs, MAF, fuel filter, air filter. Good idea would be to do a service, also check/change your plug wires. Not sure if ignition timing has anything to do with it, but check it if you have a chance.
Old 11-23-2003, 03:51 PM
thrasher thrasher is offline
classic symptoms of a FUEL PUMP problem...that should be where you look first
"Don't have sex man. It leads to kissing and pretty soon you have to start talking to them."
Steve Martin.
Old 11-23-2003, 04:45 PM
Thanks
Thanks for the advice. The ECU codes from the check engine light showed a 5th cylinder misfire and a knock sensor. I checked the spark plugs/wires and they look good. So does the air filter. I am wondering if I got a bad tank of gas? I filled up with the cheap 85 octane, but who knows if it was mostly water.
I will check out the other ideas you listed and let you know. Thanks!
Old 11-23-2003, 11:29 PM
jmd102 jmd102 is offline
You may have a restricted or faulty injector. This can cause a lean condition and pre-ignition (possibly) causing the knock sensor to do its job. But as the other posts suggest, I'd definately check fuel pressure as thrasher says first before guessing wrong. Goodluck.
Old 12-02-2003, 10:17 AM
dwntwnjewels dwntwnjewels is offline
Send a message via AIM to dwntwnjewels Send a message via Yahoo to dwntwnjewels
Arrow Re: I am having the same problem
I had this same problem. I made sure I filled the tank with super premium gasoline, the best injector cleaner you can get, it was back to normal within two days. Have to reset the check engine light though. Make sure your plugs aren't bad. If they are, replace.
Originally Posted by tkiser
Hello,
Thanks in advance!
Old 12-03-2003, 11:06 AM
Thanks
Thank you to everyone. After checking all of the above.... I filled my tank with supreme gas and some "Gumout" fuel injector cleaner additive and my car is now back to normal. I reset the check engine light and it hasn't come back on since. I guess I will start paying for the more expensive gas now....or at least every couple times I fill up.
Old 12-19-2003, 09:36 PM
Running old gas out first
In response to a few personal emails I received.... I did run all of the bad gas out before refilling with Supreme Gas. I mixed the fuel injector cleaner with the new tank of gas, and the knocking and shaking stopped after burning about 1/2 to 3/4 of the new tank. I used a fuel treatment with the next tank of gas, but not sure it was necessary and I have not added anything to the fuel the last two times I filled up. It has been over a month now and no new problems. Just a larger receipt when I fill up at the gas station....but I think it is worth it.
Old 12-20-2003, 07:15 AM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Re: Running old gas out first
You should never use anything less than 91 in your tank, it even says so in the owner's manual, also for the Nissan engine's it is not required for you to have to use any fuel additives.
I'm happy that you didn't have any major problems though because from your first post (thread starter) it seemed to be more than that.
Most commonly when you have a check engine light, it is usually oxygen sensors or worse, maybe even ignition coils or the worst a blinking light is worst than a solid check engine light<this usually indicates a major problem.
Others include: Engine Wiring harness, auto tranny failure or engine failure from a thrown rod.
By the way, it should read bk2k3Max, not bk2kmax.
Old 12-25-2003, 06:26 PM
98SEMaxima's Avatar
98SEMaxima 98SEMaxima is offline
Send a message via AIM to 98SEMaxima
I had a smiliar problem. my check engine light went on in my 95 GLE. After a long time I got it checked out and it was the timing chain and that cost 2000 to fix so I had to sell the car
98 se maxima fully loaded
www.cardomain.com/id/goten4689
Old 12-31-2003, 03:52 PM
avinashmullick avinashmullick is offline
Check Engine and Knocking
Hi I have a similar problem with my 2000 Maxima, teh check engine light suddenly came on after some knocking and engine vibration. I suspected that it must have been teh fuel injector.
Could anyone please help me and let me know how to reset the Check engine light.
Old 03-21-2004, 07:35 PM
Angry It's doing it again.
Well, I made it almost three months without problems. Now my engine is shaking at low rpms and the check engine light is back on. It doesn't shake at rpms >1500 that I can feel. It also tends to vary in intensity.
I haven't done anything different, so my hope of bad fuel is not as likely this time. Do you have any suggestions of where to look first? I have replaced my air filter, fuel filter, and plugs. Maybe the fuel pressure regulator or fuel pump? Hopefully not the timing belt?
For the above question - a good website for OCM and ECU codes is http://vbxmaxima.8m.com/ecu.html and http://vbxmaxima.8m.com/ecudecoder.html
RESETTING THE CHECK ENGINE LIGHT
To reset the engine light is a simple procedure.
1. Turn the selector screw clockwise to its stop.
2. Wait 2 seconds.
3. Return back by turning the screw counterclockwise to its stop.
4. IMMEDIATELY REPEAT steps 1 to 3.
The next time you start your engine, the check engine light should go away!
Old 03-27-2004, 09:18 PM
Talking Fixed - Bad Fuel Injector
Found it!!! I had a bad #1 Fuel injector. Replaced the 3 fuel injectors on that side and now she is running good as new! My knock sensor went bad too, so I had to replace it as well. If you ever need one...you can find them on E-Bay brand new in the box - $90 including shipping. Hopefully the last time I have to post under the "check engine light and knocking forum"
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
