Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 11-21-2001, 12:42 PM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
Unhappy My Trunk
I have the touring model with the spoiler on it and it seems to not want to open when i press the trunk release button. but when it is opened it doesn't fall. Are the shocks shot or is the trunk just that heavy?
Old 11-21-2001, 03:47 PM
G20tMW G20tMW is offline
My guess is that the remote trunk release is just that... a release for the lock mechanism. To my knowledge, the shocks are not designed to actually lift the lid to the fully opened posistion...only support it when it's up. At least this seems to be the case, with any car having hydraulic trunk supports that I have owned...this being only the second, (both with spoilers) and the other being a different make hatchback model. The spoilers do add a lot of weight tho...maybe the lids without one open on their own? I think some makes and models just work better opening the lid higher, due to design of the lid... ie flat, as on a full size type car, opposed to one with a lip that overhangs and adds extra weight at the edge furthest from the strut. Some heavier types just need a little manual assistance before the weight and the strut create a balance enough to raise on its own. Maybe heavier (or actually lighter) duty struts would be the only answer...so the lid would have less resistance and open more freely...but, then it might not stay up!
Got an affinity for my Infiniti!
Old 11-21-2001, 05:30 PM
atomic-G's Avatar
atomic-G atomic-G is offline
Send a message via ICQ to atomic-G
When I pop the trunk with the release button, it doesn't open all the way, rather just slightly and the rest I have to open manually. It is a heavy trunk .
Old 11-21-2001, 06:54 PM
NismoG20 NismoG20 is offline
my truck release dosnt even open it... i have to use my key every time i wanna get in my trunk...
lucky i dont use my trunk for anything cause its filled with my audio stuff
Craig....
--->redline all the way baby!
Old 11-21-2001, 07:54 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
On the t that I know, that trunk is so heavy, when you hit the button, the trunk doesn't even pop up a little, but it still releases.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 11-21-2001, 08:09 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
I dont think the trunk is supposed to open all the way. Mine only opens a little also.
Old 11-22-2001, 09:39 AM
Mine doesn't open at all either. Which is why I am worried. The latch releases the trunk, cause the light comes on, but the trunk doesn't open.
Old 11-22-2001, 11:01 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
On my 93.5 I had to replace the trunk actuator that unlocked the trunk...so im assuming you're having the same prob. U can do it yourself, just order the part its like $100. What I suggest is that when you close the trunk from now on, that you dont let it slam down, but let it come down to right around where it closes and then very gently push it locked. This should prevent alot of stress on the mechanism and it should keep you from having to replace it in the future.
-Brian Jones
I got a snake man
Old 11-26-2001, 08:52 AM
I'm Not following you guys..... Why would I have to replace the actuator if the trunk doesn indeed unlock it just doesn't lift any where?
Old 11-26-2001, 10:27 AM
Mrcoilover Mrcoilover is offline
not supposed to lift, just unlock. There is nothing wrong with yours.
*Mod List*
2 JL audio W3 12's
Rocksford Fosgate 600w amp
Tein type NA (1.7)
Nokya Arctic purple headlight bulbs
Rims coming soon...
"I always ride dropped, how bout you?":finger4:
Old 11-26-2001, 01:48 PM
so in essence i will always have to use my key to open the trunk. boy that sucks...........
Old 11-26-2001, 02:24 PM
Well if your trunk don't unlock when you hit the switch, then you do have a problem. take it to da dealer and see wassup.
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-27-2001, 11:43 AM
It unlocks. It just doesn't open. Imagine unlocking your driver side door and it not opening. Of course your drivers side door is supposed to do that, but the trunk isn't. It shoud at least crack a little bit to allow me the chance to open it up. Nope it doesn't even do that. The trunk light comes on signifying that it is doing something. I guess the two springs on the side aren't strong enough to push the trunk up an inch or two to facilitate the opening of the trunk.
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 11-30-2001, 02:40 PM
King of DUB-C's Avatar
King of DUB-C King of DUB-C is offline
With my trunk I have to use my keyless entry and pull at the same time but it is because I put a spoiler on it, which will weight it down. Otherwise it is suppose to unlock and thats it, the trunk doesn't open itself!
difference between 2 door trunk/hatch and 2+2 trunk hatch blingboy69 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 7 09-05-2007 09:24 PM
Trunk Doesnt Pop Up When I Pull The Trunk Lever? toicy4ya Off-Topic 7 07-15-2005 11:58 AM
**please help..trunk motor not working,food in trunk!! stockbizz 5 Series 2 04-09-2005 09:29 PM
I just bought a 95' del Sol... need trunk dimensions! Anyone know how big trunk is? Northmont Del Sol 12 12-30-2004 11:51 AM
trunk release (on door) won't fully unlatch the trunk - anybody heard of this? tim-may General 7 01-26-2002 10:52 PM
