Go Back   Automotive Forums .com Car Chat > Ford > Ranger | Courier
Old 06-23-2016, 08:34 PM   #1
Pappy01
Transmission issues
I have 1996 Ranger with 2.3 4 cyl with a 5 speed tranny. Tranny started acting up not letting me down shift from 3rd to 2nd now it won't up shift to 2nd an on occasion will kickout out of reverse and lurch forward. Any ideas????
Pappy01 is offline   Reply With Quote
Old 06-24-2016, 11:05 AM   #2
MikeCStig
Re: Transmission issues
Sounds like your synchros are acting up. Drain your gear oil and pass it through a coffee filter. If you see a lot of metal shavings, that's probably what it is. If that's the case, the transmission has to come out for some serious repair or replacement
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
MikeCStig is offline   Reply With Quote
The Following 2 Users Say Thank You to MikeCStig For This Useful Post:
Pappy01 (06-27-2016)
Old 06-24-2016, 07:56 PM   #3
Pappy01
Thanks for the advice another tranny maybe in order friend told me to check the shifter connections but now I'm doubtful of that.
Old 06-27-2016, 06:48 AM   #4
Pappy01
drained the tranny only had 1 1/2 cups of fluid, found the shifter bushing missing awaitng a replacement if this doesn't help looks like another tranny.
