Go Back   Automotive Forums .com Car Chat > Buick > Riviera
Old 07-05-2012, 10:52 PM   #1
Oldtin4me
Unhappy 95 buick riviera hard to start hard to keep running
Hi guys and gals I just replaced the supercharger on my 95 riviera and I am getting a really rough idle if it wants to stay running at all. I can keep it ruining if I stay on the gas but it has a real problem getting up past rough idle and is rough all the way through to 3500 after a while of holding it around 3000 or so it smooths out but still seems to have a bit of a miss and I have a check engine light that comes on after a little bit of running then it starts running rougher almost immediately Also may be unrelated but i the higher the rpms climb the fuel gauge reads less and less gas (haha I know thats what happens) and then if the rpms drop it starts reading more gas.
Oldtin4me is offline   Reply With Quote
Old 07-06-2012, 08:45 AM   #2
Tech II
Re: 95 buick riviera hard to start hard to keep running
Why was the SC replaced? Bearing problem?
Was the rough idle there before replacement?
Sure sounds like a possible vac leak.....
Tech II is offline   Reply With Quote
Old 07-06-2012, 10:03 PM   #3
Oldtin4me
I replaced it because my old one was making a really annoying noise at idle and I thought the bearings were bad but then found out about the couplers in them go bad really often so I replaced that too.
There was not an idle problem before but it would throw the same check engine light and trac off light and it would make the car run rougher as soon a they popped up then if I shut the car off it would start back up and no lights or codes recorded in history.
Im going to check for vac leaks tomorrow but I think the engine light is still going to be there any ideas on that.
Thanks so much for any help
Old 07-07-2012, 09:41 AM   #4
Tech II
If it started to run rough when the CE light came on, what are/were the codes? If that CE ight comes on, there has to be a code in history.....
Old 07-12-2012, 12:52 AM   #5
HotZ28
AF Moderator Elite
HotZ28's Avatar
There is a vacuum/boost line in the LIM, which is located below the S/C snout and goes to the MAP sensor. Are you sure that is connected?
HotZ28 is offline   Reply With Quote
1994 Ford Explorer Hard starting after it sits. privottfamily Explorer | Explorer Sport Trac 3 05-01-2012 06:14 PM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 02:17 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 05:21 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 09:52 PM
95 Buick Riviera - won't start rkillion76 Riviera 6 03-21-2006 08:59 AM
