Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 06-29-2012, 05:03 PM
jtiderencel jtiderencel is offline
Send a message via Yahoo to jtiderencel
03 dakota, 3.9-v6, fast flashers
the problem is my turn signals flash real fast. same when using the hazards. the audible click is the same as indicator on the dash, but fast.
all bulbs work and are bright. fuse is good, but have not changed the combination flasher under the dash.
any idea why they would flash real fast.
NATURE OF THE BEAST?
Old 06-29-2012, 05:25 PM
jpb53 jpb53 is offline
Re: 03 dakota, 3.9-v6, fast flashers
You need to do a very good inspection of all the circuits.
OPERATION
The combination flasher controls the following inputs and outputs: fused B(+), fused ignition switch output, right turn signal sense, left turn signal sense, hazard flasher signal, brake lamp switch output, and two outputs each for the right and left turn signal circuits. Constant battery voltage is supplied to the flasher so that it can perform the hazard warning function, and ignition switched battery voltage is supplied for the turn signal function. The Integrated Circuit (IC) within the combination flasher contains the logic that controls the flasher operation and the flash rate. The IC receives separate sense ground inputs from the multi-function switch for the hazard flasher, right turn signal, and left turn signal. A special design feature of the combination flasher allows it to "sense" that a turn signal circuit or bulb is not operating, and provide the driver an indication of the condition by flashing the remaining bulbs in the affected circuit at a higher rate.
I f the combination flasher is believed to be faulty, test the turn signal and hazard warning system. Then replace the combination flasher with a known good unit to confirm system operation. (Refer to 8 - ELECTRICAL/LAMPS/LIGHTING - EXTERIOR/TURN SIGNAL & HAZARD WARNING SYSTEM - DIAGNOSIS AND TESTING
Old 07-19-2012, 07:15 PM
took your advice. inspeced all circuits and lights. in the back had water in one lens, the front had wrong size bulbs on one side. after replacing two bulbs and a little white grease, all lights work bright and a normal speed.
jpb 53, thanks
jt
95 Dodge dakota, 3.9 V6 two weel drive, Failed NOX, to high Richter1234 Dakota 5 11-03-2010 11:03 AM
89 dakota w/ 3.9 v6 rumjy Dakota 4 01-23-2010 07:16 AM
93 Dakota 3.9 running prob jdmhvac3 Dakota 31 12-30-2004 09:27 PM
93 Dodge Dakota 3.9 A/C problems bmayer13 Dakota 1 08-12-2004 04:01 PM
98 dakota 3.9 liter rocker arms fast98gtp Dakota 1 04-03-2004 11:32 PM
