Go Back   Automotive Forums Car Chat > Lincoln > Town Car
  #16
Old 04-13-2012, 04:07 PM
All2kool's Avatar
All2kool All2kool is offline
Re: Gas Mileage Is Too Low On Town Car
Originally Posted by olopezm View Post
Are you talking about the IAT (Intake Air Temperature) sensor?
I think it was removed from the airbox to be relocated into the MAF sensor itself. That's why some newer models have a 6 pin MAF sensor.
Oscar.
Probably, but then again, I'm not sure on a 2002. On the 1996, there is a Sensor (of some sort) mounted to the Air Box.
Old 04-13-2012, 10:57 PM
02LincolnTownCar 02LincolnTownCar is offline
I did see a sensor attached to the hose leading into the air filter box but it was still attached and i never touched it. However i did get to change the fuel filter today and the miles per gallon reset to 0 and now it's up to 9.5 to 10 i have the plugs (platinum) and new boots which will probably be put on tomorrow tried to change the pcv valve but the one they gave us did not match and when the guy looked it up it was the same one he had gave us so well try another store tomorrow. I'll keep you all posted and thanks for the input.
2002 Lincoln Town Car
Old 04-14-2012, 11:47 AM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I would advise you to get an OEM PCV valve. Many people says the aftermarket one's don't have the same properties as OEM's do.
Just in case and even if you get an OEM or aftermarket PCV, the new one will come with TWO openings instead of just one (not sure if your model needs both openings) and a small plastic cap. If you need only one, install the cap on the upper (smaller) opening and you're all set.
Let us know if the spark plug and boots make any difference.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 04-14-2012, 08:55 PM
YellowFly YellowFly is offline
Since you mentioned you haven't driven very far or fast, I'd suggest you confirm your transmission is up-shifting properly and/or you don't have any brake drag.
Old 04-14-2012, 09:21 PM
Towncar's Avatar
Towncar Towncar is offline
Originally Posted by 02LincolnTownCar View Post
...it seems to be holding steady at 8.5 miles a gallon but that's still not normal, wish me luck tomorrow and thanks for all the input and suggestions.
DONT depend on the 'dash mpg' meter for actual MPG's.. run full tanks and calculate your MPG's at each fill-up. miles / gallons.
Another example of the above comments.. when I drive my cars I get 30% better MPG than my wife.. she brakes at the last minute, takes off hard, etc.
-Steven
1996 Town Car, Cartier
Old 04-14-2012, 11:43 PM
All2kool's Avatar
Exactly!
How you drive any vehicle will be a big factor in the fuel economy.
Old 04-15-2012, 06:31 PM
Oscar.
I think my car needs the one with one opening but i will definitely try to get oem
Old 04-15-2012, 06:34 PM
i don't know how to technically check the up-shift but the trans shifts nice and smooth and she is fast i might have air in the brake lines but i have to wait for my uncle to help me bleed and flush
Old 04-15-2012, 06:37 PM
That's almost how I drive but i have been trying to slow down lately and i have been doing that coasting trick and it really does work so hopefully with the plugs and boot wire change i'll at least get 20 mpg's
Old 04-21-2012, 02:36 PM
I finally got around to changing the plugs and wires I got all out but one I think i'll need an extra extension it's in there pretty tight. the mpg went up to 12 so i still need to find out whats holding it back, thanks for all the input and suggestions.
Old 04-25-2012, 06:09 PM
olopezm's Avatar
Mine's got around 12MPG's when driving around town in moderate to heavy traffic. Depending on how far I drive on the highway it can get up to 18-19MPG's ( after around 100 non-stop miles that's the fartest I've driven this car on the highway).
Oscar.
Starting problem, decreased gas mileage on 97 suburban mlhempton Suburban 0 05-10-2011 03:39 AM
Better gas mileage Stapletonb08 Cavalier 3 03-03-2011 01:02 PM
City gas mileage too low. LYLY Caravan | Voyager 2 02-08-2010 12:00 PM
Tags
2002 , car , gas , mileage , town
