Old 03-17-2012, 07:35 PM
vair guy vair guy is offline
96 LeSabre Coolant leak
Hello again, My 96 LeSabre has a coolant leak. It appears to be from the front of the motor under and harmonic balancer. Figuring the leak the was coming from somewhere else I looked around the top of the motor. I noticed the water pump pulley seemed to have some extra play in it. Figuring that's where the leak was coming from I got another one. In the process of pulling it out I noticed it was bone dry. So I have a new water pump but still have a HUGE leak. It got dark outside so I'm going to wait till tomorrow to try and do a better job of tracing it down. I was just wondering is there anything in the balancer area that could be leaking coolant?
Old 03-17-2012, 08:08 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 96 LeSabre Coolant leak
Are you sure it is not leaking down from another source? Did you install the new water pump? Have you checked the coolant bypass elbow?
Old 03-17-2012, 08:52 PM
I have to clean everything, get under the car, and run it to know for sure but the leak is very bad so it shouldn't be to hard to find. I go threw almost as much water as I do gas.
Old 03-17-2012, 09:14 PM
I was just kind of wondering that if I do find its leaking from the bottom front of the motor what could it be?
Old 03-17-2012, 10:25 PM
HotZ28's Avatar
AF Moderator Elite
It has to be from a source from above the harmonic balancer. There are no coolant passages, or hose below that! Have you checked the bottom radiator hose? It could have a pin hole, spraying coolant in any direction.
Old 03-17-2012, 11:13 PM
That's good to hear. I don't want to have to take that balancer off. I'll let you know what I find out tomorrow.
Old 03-18-2012, 09:48 AM
DeltaP DeltaP is offline
Ya need to pressure test the cooling system. Alot faster and safer than crawling under and around a running engine.
Old 03-18-2012, 10:40 AM
auto trainy auto trainy is offline
The most common place would be the by-pass elbow on the belt tensioner but a pressure test would be sure,Good Luck.
Old 03-18-2012, 02:34 PM
Looks like it was the water pump. Weird how that thing was bone dry when I pulled it out.
Thanks for the responses.
'93 lesabre coolant leak behind the throttle body CAMFLIGHTRN LeSabre 7 01-21-2012 02:49 PM
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
95 Lesabre Coolant Leak at Throttle Body Gnomonic LeSabre 4 06-01-2006 12:03 PM
