Old 08-26-2011, 07:08 AM
radial2112 radial2112 is offline
98 Chevy S-10 ABS 4wal brakes
Is it absolutely necessary to use a brake scan tool to bleed the brakes on a
1998 Chevy S-10, 2.2 motor, 2 wheel drive? I know that there is air in the
modulator because the right rear line blew and the master cylinder ran dry
in the front resevoir.
Old 09-08-2011, 09:19 PM
old_master's Avatar
Advisor/Moderator
Re: 98 Chevy S-10 ABS 4wal brakes
Yes, it is absolutely necessary to use the scan tool. Without performing the "automated bleed", you'll never get all of the air out of the ABS unit.
You have to know how it works,
to figure out why it doesn't.
ABS Hydraulic Unit tips for rebuilding bertpalm General Discussion 0 01-16-2010 08:00 PM
2000 S-10, ABS and Brake light issue - have codes, need advice!!! wshuart S-10 12 10-07-2009 07:56 PM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 09:51 AM
2001 S-10 ABS and BRAKE light problem mg2low S-10 1 05-09-2007 07:18 PM
'93 Chevy S-10 w/ no Brake, Back-up or Rear Directionals mickeyash Problem Diagnosis 2 12-20-2006 05:27 AM
