Codes 403 and 1443 and I go from 23 to 16 mpg ???
The print out from autozone has code 403 saying:
The ECM has detected a fault in the EGR solenoid circuit PROBABLY CAUSE Failed EGR vacuum solenoid Open or short circuit condition of the EGR valve Failed egr pressure sensor where applicable Failed EGR position sensor where applicable and 1443: ECM detected a fuel tank pressure change greater than -7 inches of h20 in 30 seconds with purge less than .02 lbs per minute PROBABLE CAUSE Failed EVAP sensor Blocked hose between FTP and EVAP sensor EVAP purge valve stuck closed I really just care about what gonna get me back up to 23mpg Any ideas guys?? I took the DPFE sensor off. I heard and some say that that can cause EGR problems. SHould i do anything with it now that its off? clean it? Thnx. Vehicle specs: 95 Ranger, 4 cyl, ext cab, 260k miles, 2wd |
