Old 07-12-2011, 01:12 PM
ernesto821 ernesto821 is offline
A/C compressor not clicking
Hi all,
the A/C relay is not clicking in my 2003 pontiac Grand AM 2.2L.. I checked the fuse and diode associated with the A/C both are fine. The relay also works when tested... Is there any other reason why the relay wouldn't click when I turn the A/C on?
thanks
Old 07-12-2011, 02:17 PM
procaddytech procaddytech is offline
Re: A/C compressor not clicking
There could be several other reasons. The BCM may not be getting the A/C request from the HVAC control assy. The PCM may not be getting the request from the BCM to ground the relay. The A/C pressure sensor may be reading less than 27psi or more than 432psi. (Low refrigerant charge or electrical fault) Ambient temperature sensor may be reading less than 38*F.
Old 07-12-2011, 10:30 PM
thephantom1492 thephantom1492 is offline
There is also another reason: coolant temperature too hot (engine overheating)
The most likelly cause is a low refrigerant charge due to a leak.
Do NOT blindly refill the system, overcharging the system can/will cause compressor failure.
Old 07-15-2011, 07:05 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
might also check other fuses associated with the fans and their relays
1999 Grand Am SS 3.4 OHV
a/c compressor makes clicking noise PBFreeland Explorer | Explorer Sport Trac 5 07-15-2010 05:42 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 07:44 PM
cirrus 95 v6 A/C compressor not turning on gogodogo Cirrus 1 03-01-2007 05:18 PM
AC Compressor Keeps Clicking On mvee61 Blazer 4 11-24-2005 08:07 AM
A/c Compressor Not Clicking On/off RICHARD312 Ram Pickup | Ram SRT10 0 08-11-2005 08:22 PM
