Go Back   Automotive Forums .com Car Chat > Pontiac > G6
Old 07-08-2011, 03:29 PM   #1
bruker
bruker's Avatar
Question No door chime or turnsignal "click".
I did a search but found nothing about this. My daughter has an `08 G6 and recently the door chime and turn signal "click" sound stopped working. Everything works fine but I'd like to get things working like they should. Is there a seperate chime module that I need to replace or is this something else? Thaks for any help!
bruker is offline   Reply With Quote
Old 07-08-2011, 03:59 PM   #2
jdl
Re: No door chime or turnsignal "click".
If the turn signals work, why do you need the click? My hearing is no good, can't hear click anyway.
Some info on warning chimes below.
jdl is offline   Reply With Quote
Old 07-15-2011, 07:27 AM   #3
bruker
bruker's Avatar
Turns out the problem was the chime module that's attached to the back side of the instrument panel cluster. Unfortunately the chime module is not something that can be replaced so I had to replace the entire cluster. I bought a used one off E-bay for $45 and replaced it myself.
1994 driver door chime won't stop while door is open... my94baby SC/SL/SW 4 08-08-2007 08:30 PM
Drivers Side Door Chimes with no key in ignition and with headlights off & door open trainerjim23 Focus | C Max 5 06-09-2007 08:39 PM
91 caravan door chime Tom Breit Caravan | Voyager 1 09-02-2006 08:28 PM
01 Grand Am door chime, dome light, door lock & remote Doug Campbell Grand AM 10 06-17-2005 04:42 AM
Door Chimes WhtVR6 Jetta/Vento/Bora 2 08-26-2002 10:14 PM
