Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 04-10-2011, 06:08 PM   #1
acarinneed
92 Lumina won't crank
I parked it and about 3 hours later it wouldn't crank. Charged the battery with no result. I hear a relay clicking under the hood near a small fuse box on the drivers side wheel well. I also hear the fuel injector-type thing make a noise as it sprays fuel. However, I hear no noise from the starter (no clicking or anything). I've done nothing else. Engine is 3.1 w/auto trans.
acarinneed is offline   Reply With Quote
Old 04-11-2011, 08:04 PM   #2
maxwedge
A990 racer
Re: 92 Lumina won't crank
See if you have 12v to the sarter solenoid when attempting to crank.
maxwedge is online now   Reply With Quote
Old 04-12-2011, 09:57 AM   #3
acarinneed
Thanks, maxwedge. The weather hasn't permitted me to get to the car yet. But when I can, I will do that (after I check and clean battery posts/terminals and put a charge on the battery). Thanks, and I'll post the results.
Old 04-29-2011, 02:09 PM   #4
acarinneed
The weather finally let me check some things. I have good battery voltage. When I try to crank it, the headlights don't dim. I have full voltage at the starter on the big solenoid terminal, but no voltage on the purple wire terminal, even when turning the ignition to crank. But if I short the purple wire terminal and the big terminal on the solenoid, it starts right up and runs fine. What thing(s) should I look at next? Thanks!
Old 04-29-2011, 08:01 PM   #5
maxwedge
A990 racer
That purple wire has to go thru the trans prndl switch which I believe is on the top of the trans where the linkage enters, back track thru it back from there.
Old 05-01-2011, 11:25 AM   #6
ibbobud
Theres a seperate neutral safty switch located at the steering column that would prevent this. To test this theory you could find the switch connector and bypass it temporarly and see if the car starts. if so then either replace the switch or permanently bypass it.
** WARNING ** bypassing this switch will all your car to be started while in gear!
90 Lumina euro 3.1 - New fuel pump/filter, new ecm, new egr valve, new upper/lower intake gaskets, new alternator, new O2 sensor, and it keeps going....
ibbobud is offline   Reply With Quote
Old 05-01-2011, 03:55 PM   #7
maxwedge
A990 racer
I believe 92 was on the trans, could be wrong though. Autozone.com, repair guides has the info.
1990 lumina won't start w/new cps/ign mod carkid7 Lumina 1 07-30-2010 12:42 PM
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-03-2010 12:37 AM
98 lumina won't crank Thatguy85 Lumina 18 04-21-2010 12:56 AM
95' Lumina won't stay running Jeremy Granite Lumina 5 07-29-2009 05:32 PM
1992 Lumina Euro 3.1L won't crank robmcisaac Lumina 3 11-22-2006 11:04 AM
