Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 02-28-2011, 02:58 PM   #1
bsr2002
Question Bad Idle 98 Lumina 3.1
My car has been running great till the other day. I got into the car to go to work when the car wouldn't start. I would put the key in the ignition and everything seemed ok lights etc...but when I turn the key, the lights would turn off and the car would not start. No cloicking no nuthin.
I then took the battery out and had it checked and all is ok with it...I even cleaned the terminals.
I then put the battery back in and this time it starts. But now the idle is bad. It will randomly rev the engine like I was pressing the gas pedal, but I'm not.
I was gonna try to drive it around the block but it would stutter like it was going to die...
Any ideas?
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
bsr2002 is offline   Reply With Quote
Old 02-28-2011, 03:23 PM   #2
inafogg
Re: Bad Idle 98 Lumina 3.1
since you removed the battery it may need to reset itself, by idling/driving
it may/should clear itself
but if im mistaken someone will chime in
i guess bad connection caused the no start?
good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
inafogg is offline   Reply With Quote
Old 02-28-2011, 03:54 PM   #3
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Yeah it's hunting for idle speed, the idle memory disappears after 10 mins or so of no power.
If you have a factory stereo, it's probably locked out too.
Drive it, it may die when you stop, or idle too high or low, but it should recover after 20 mins or so of driving.
Or you can set the ebrake, chock the wheels, start it and let it run in gear for a while...it'll sort it out on it's own...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
The Following User Says Thank You to jeffcoslacker For This Useful Post:
bsr2002 (02-28-2011)
Old 02-28-2011, 06:25 PM   #4
bsr2002
Cool! I will try that when I get off of work this evening!
THANX
Old 02-28-2011, 11:53 PM   #5
bsr2002
Thanx again guys, all is back to normal
Old 03-01-2011, 12:59 PM   #6
inafogg
good to hear thanks for the reply
Live For Today
Yesterday is gone,
1991 Cutless supreme 3.1 stalling mandude Cutlass Series 9 02-06-2015 01:16 AM
Lumina keeps dieing?? Smacky Lumina 1 02-03-2011 03:28 PM
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 07:37 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 09:55 AM
3.1 interchange info please. Ponyak Grand Prix 2 06-08-2009 11:58 AM
