Go Back   Automotive Forums .com Car Chat > Ford > Econoline
Old 01-19-2011, 11:37 PM   #1
IM2HI2CU
1985 E150 dual tank wiring
I have searched around trying to find a wiring diagram for the fuel delivery system. I have a 1985 Ford E150 with dual gas tanks. I have a Chilton Ford Pick-Up and Bronco 1976-1986 but the wiring diagram for the 1985 F150 does not match the color wires for the plug at the fuel tank switch.
I have a replacement switch that was produced by Ford (Motorcraft switch E6UB-9A050-AB) and the wire connector plug (Ford D9AB-14489-JD) to be spliced into the existing wire harness coming out from the center of the dashboard.
OK, here is my problem. The stock wiring connector has 5 wires going into the stock switch. The stock switch also has offset terminals so it will only go on one way.
My replacement switch has 6 symmetrical terminals. The replacement wire connector has 4 wires coming out of the back of the connector switch to be spliced into the existing wiring and two of the wires double back to other terminals for a total of 6.
The stock color wires are:
green/red
black/orange
red/yellow
orange
green
The replacement color wires:
black
red/yellow
red/tan
brown/orange
Autozone lists a switch for my year that have 6 screw connections (SW48) but I wouldn’t know how to wire that switch to my stock wiring, or what terminals doubled-back to another terminal.
Urgh!!!! I hope that I explained my problem with enough information. Thanks guys.
IM2HI2CU is offline   Reply With Quote
Old 01-23-2011, 01:07 AM   #2
IM2HI2CU
Re: 1985 E150 dual tank wiring
I just got it hooked up and i can hear the solenoid switching, the gauge goes from way below E when the ignition is off, to right on E when the ignition is on. When I switch tanks there is hardly movement in the needle and hovers around E, if not moving at all.
I new that both tanks were almost empty, I will get some gas tomorrow.
Old 02-02-2011, 12:24 AM   #3
IM2HI2CU
I grounded both gages and both peg full.
Went to RS and got a switch DPDT 10A 6-pole toggle switch with center off position (#275-1533). Everything works! The additional perk is to have the central off position to turn both fuel supplies off. Oh, and it cost $4.27 including tax.
Just wanted to follow up on the post
FAST IDLE with New IAC - 2001 E150 5.4 leroge Econoline 0 01-19-2011 05:46 PM
1985 k10 headunit wiring redka88 C/K 0 04-22-2009 09:53 PM
F150 Dual Tank Bad Fuel Pump or ??? wen F Series 2 03-23-2004 12:43 AM
trouble with dual tanks craigcully F Series 1 01-16-2004 08:02 PM
Fuel pump out? 1987 dual tank bj1975 C/K 1 10-23-2003 12:16 PM
