Go Back   Automotive Forums .com Car Chat > Ford > Crown Victoria
Old 09-02-2010, 10:06 PM   #1
pdlandry
1998 ford crown vic windshield wiper motor
Wipers not going back to down position. Changed motor, worked correctly two times. Now wipers are not quite in correct position.....better but not all the way in cradle position?
pdlandry is offline   Reply With Quote
Old 09-02-2010, 10:38 PM   #2
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 1998 ford crown vic windshield wiper motor
Are the wiper arms on correctly? One spline off can be a cm or so off of the park position. Otherwise, it may be the multifunction switch or governor.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
Old 09-02-2010, 11:15 PM   #3
pdlandry
after installing new motor, positioned wipers to rest in cradles. Worked OK only a couple times. Now wipers are stop at position couple inches from cradles?
