Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 06-08-2010, 04:31 AM   #1
McLin
McLin's Avatar
Intake Manifold leak detection...
Hi,
how can I find out which intake manifold is leaking?
I lost coolant, so I can fill up every 2 wekks from hot to cold mark if the engine warmed up.
the oil looks fine, but the coolant must leaking somewhere.
So how can I find out which manifold is leaking?
Oh it smells like burned plastic in the engine area if the engine warmed up.
thx.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
McLin is offline   Reply With Quote
Old 06-08-2010, 12:14 PM   #2
Airjer_
Airjer_'s Avatar
Re: Intake Manifold leak detection...
What year, what motor?
Airjer_ is offline   Reply With Quote
Old 06-08-2010, 02:15 PM   #3
McLin
McLin's Avatar
Sorry 3.8L Series 2 1998 LTZ
Best regards McLin.
My Lumina
Mileage:
Old 06-08-2010, 03:48 PM   #4
maxwedge
A990 racer
More than likely it is the upper intake, the egr passage is close to the coolant passage behind the throttle body, this melts thru and coolant gets into the engine.
maxwedge is offline   Reply With Quote
Old 06-08-2010, 04:16 PM   #5
McLin
McLin's Avatar
Cool thx.
From Rockauto.com:
DORMAN Part # 615180 {OE Solutions; Includes All Gaskets and Seals as Required #89017272}
Includes All Gaskets and Seals as Required; w/5-5/8" (145mm) Diameter Alternator; Designed specifically to work with Dorman OE Solutions Intake Manifold Gaskets only.
Includes All Gaskets and Seals as Required; w/5-1/8" (130mm) Diameter Alternator; Designed specifically to work with Dorman OE Solutions Intake Manifold Gaskets only.
Is this a good replacement part?
Best regards McLin.
My Lumina
Mileage:
Old 06-08-2010, 08:06 PM   #6
maxwedge
A990 racer
Yes, had one on my 98 LTZ.
Old 06-12-2010, 01:08 PM   #7
McLin
McLin's Avatar
Today I had filled in some water in the coolant reservoir. I saw some oil on the top of the cooling water.
My question is: Is the same symptoms for upper intake manifold? Is there any oil line where can get oil in the cooling water?
I did replace the lower intake manifold on another Lumina, but the symptoms was that coolant goes in the oil...
Best regards McLin.
My Lumina
Mileage:
Old 06-12-2010, 02:58 PM   #8
maxwedge
A990 racer
Trans fluid could get into the cooling system thru the trans cooler in the radiator, but that would be reddish, not brown.
Old 06-12-2010, 04:19 PM   #9
McLin
McLin's Avatar
nop, it was brown...
If there is a leak in the upper intake manifold then its possible that the oil in the intake manifold can get into the coolant passage? Maybe if the engine is cold and the pressure is not high.
I dont know how possible that is.
Best regards McLin.
My Lumina
Mileage:
Old 06-12-2010, 08:51 PM   #10
maxwedge
A990 racer
It is all guesswork, take off the throttle body and look at the egr and coolant passages for a better idea of what may be happening.
Old 06-14-2010, 04:17 PM   #11
McLin
McLin's Avatar
I ordered the Intake Manifold Set and the Fel-Pro Intake Manifold gasket kit ,with all gaskets.
I dont open the engine without new parts. I report then what it is.
Best regards McLin.
My Lumina
Mileage:
Old 06-17-2010, 05:05 PM   #12
mastertech1964
its a common problem with the 3.1 and 3.4 engines to have the lower intake leak coolant gm has a redesigned gasket set available the quick check is to look for staining where the lower intake and heads meet the engine block at the lifter valley check both the pulley end and trans end of the engine
mastertech1964 is offline   Reply With Quote
Old 07-06-2010, 02:15 AM   #13
McLin
McLin's Avatar
I I replace the parts, can I take away the lower cooler hose and run the engine a couple of second that the most coolant go out?
Best regards McLin.
My Lumina
Mileage:
Old 07-06-2010, 06:32 AM   #14
maxwedge
A990 racer
Yes.
Old 08-04-2011, 12:31 PM   #15
dazarooney
Did you fix the problem McLin?
dazarooney is offline   Reply With Quote
