Old 05-18-2010, 09:03 PM
goongrinch goongrinch is offline
audi 1.8 turbo
having the timing belt one tooth off on a audi a4 1.8, wouldnt that cause a check engine light to come on, so far one hasnt came on but the thing seriously has no power.
Old 05-19-2010, 09:40 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: audi 1.8 turbo
It may or may not set a trouble code if the ECM can compensate for the timing problem by advancing/retarding the spark timing....within the range of its programmed maps.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 05-19-2010, 12:12 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: audi 1.8 turbo
I'm assuming, based on the question, that you just changed the timing belt. Did the vehicle have low power before the timing belt change and that's why you suspect it's a tooth off, or did it run like this before as well? You might have this thread moved to the Audi A4 forum as the regulars there probably have a few more specifics on the car and tricks to changing the timing belts to watch out for.
Other than the lack of power does the engine seem smooth and idle decent?
-Rod
Old 05-20-2010, 10:44 PM
RahX RahX is offline
Re: audi 1.8 turbo
Spark timing wouldn't help the situation very much since it would actually be a problem with mechanical valve timing. Depending on which way it is off, you gotta figure that for every tooth that the cam is off, it would put the cam anywhere from 5 to 10 degrees out of time. Not sure how many teeth are on the gear(s) on the 1.8 but if you think the thing is out of time MAKE SURE IT ISN'T. Unless the PCM is setup to specifically monitor cam/crank timing, the only codes it might set are misfires and rich/lean conditions. You could do some serious damage if you don't do anything about it asap.
