is there a way to check whether my 98 camry has factory installed keyless entry when we just bought it no fob. thanks
Re: How do u check 4 factory installed keyless?
Easiest way is to call your local dealer, and give them the vehicle's VIN. They'll be able to pull up all the factory installed options and tell you if it was installed. Really beats crawling under the dash. Good luck!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
will they know if a dealer installed system is present?
I'm not 100% sure on this, but if it was added as a new-car purchase, then it should be in the system. If your car still has the dealer badge stuck to the trunk, you can call that particular dealer as well to be sure.
A Toyota parts department employee should be able to pull up the vehicle by the VIN # and make sure you confirm if you have the FACTORY installed system, or the DEALER/PORT installed RS3000 system.
There are 2 different types for the 98 Camry.
Replacement keyless entry remotes available here - up to 90% off - All makes/models from Acura-Volvo, 1988-present - http://www.OriginalKeyless.com |
Thanks for replying.
2008 Mazda 3i 2.0L Manual Take what lands on your plate and transform it into something you can eat. Ram Das |
