| Latest | 0 Rplys |
WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
11-11-2020, 11:24 AM | #226 | |
Re: Lola T-70 Mk III
They are urethane resin I dyed almost black.
The Following 2 Users Say Thank You to Scale-Master For This Useful Post: |
kans0002 (11-11-2020)
11-17-2020, 09:43 PM | #227 | |
Plug boots for the wires. Made using the same process as the for the distributor boots.
11-18-2020, 03:32 PM | #228 | |
And I made spark plugs too. Steel and resin; shown with a boot installed.
11-19-2020, 10:44 AM | #229 | |
I added the sand-cast texture to the block. Notice the freeze plugs and timing cover are not textured.
It still needs another coat of paint, but not until the oil and water plugs are added. |
11-20-2020, 06:35 PM | #230 | |
Thermostat housing and fuel pump block off. The kit part didn't match my intake manifold.
I was able to thin out the kit's block off plate. I machined the aluminum bolts on both parts. |
11-21-2020, 11:08 AM | #231 | |
The timing tab has been bolted to the engine.
11-21-2020, 11:53 AM | #232 | |
I added the oil and water plugs before the last coat of orange.
11-22-2020, 10:58 AM | #233 | |
The heads got the same texture treatment as the block…
11-23-2020, 10:01 AM | #234 | |
I finished the water pump after texturing it as well and making the aluminum mounting hardware and the plug for where the heater hose would go.
11-24-2020, 09:57 AM | #235 | |
Distributor hold down clamp. Also scratch-built.
11-25-2020, 10:19 AM | #236 | |
The oil pan is done for now. More machined aluminum parts too.
It's starting to look like something… |
11-26-2020, 11:08 AM | #237 | |
I made the head bolts and acid treated them because they were too bright. Added a little grunge too.
11-29-2020, 11:47 AM | #238 | |
The transaxle was lightly textured and new bolts and drain plugs were machined for it.
11-30-2020, 01:49 PM | #239 | |
The rear of the case was also done the same way and the bolts were acid treated.
12-01-2020, 11:28 AM | #240 | |
Breather can holder and mount…
