Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Old 03-17-2010, 10:30 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Re: Junkies 97 RS Rebuild(1st timer!)
Ok, so follow the torque spec listed in the book? Or tighten it harder than that
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 03-17-2010, 02:18 PM
Ok, can somebody tell me why the throw out bearing I got from mitsubishi doesnt fit ont he imput shaft at ALL? ITs way too big, and doesnt even look remotely the same as the one that was on it...is there something im missing? (new one on left)
Old 03-17-2010, 03:07 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I don't remember what the torque was. Las time I did it I wedged the motor so it couldn't turn and tightened the bolt with a tire-iron. Not right, but it got the job done.
Ya that's not the right TOB at all. New one will look exactly like the one on the right. Should be no variation between the 2. Take it back.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-17-2010, 03:47 PM
Dammit
Old 03-17-2010, 06:49 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I used an impact gun to tighten mine, not super tight but just enough to run the pulley up the rest of the way and snug it good. That bearing isin't even a TOB, it looks like a bearing for the inside of the tranny
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-17-2010, 07:32 PM
yeah, now i have to drive an hour back to the dealership, and prob again to pick up the new one....
errrrrr
Old 03-17-2010, 09:03 PM
ned032002's Avatar
ned032002 ned032002 is offline
It almost looks like it would fit inside the tb, like it's the inner guts that we can't see. Sure it's not but just an observation.
Old 03-17-2010, 09:52 PM
Ok...made some progress tonight. camshafts came out, rocker arms, timing cover, idler pulley, tensioner pulley, tensioner(do I need another one of these?) oil pan and water pump.
Which leads me to my next 2 questions.
Dont have the right socket for the head bolts, can someone who knows tell me what size I need so I can get the right one the first time and avoid several trips to sears lol..
And, the crank sprocket has to come off before I can go any further in that area, any suggestions how to do this? I cant find it int he manual how to actually remove it, it just says "remove it".....
Old 03-18-2010, 06:27 AM
Holset powered 420a
If headbolts are ARPs they are 12 point 14mm or 9/16.
Remove the pulley with a steering wheel pulley I believe, you have to find one that just has slots so you can put screws threw it and tighten them down then back it off. I dont remember the size of the top of my head but I believe they are m6x1.0 possilby. This is a tricky one to get off
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-18-2010, 08:05 AM
Great....lol. A steering wheel puller?
Old 03-18-2010, 08:40 AM
Holset powered 420a
http://www.secondchancegarage.com/ar...ing/photo6.jpg
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-18-2010, 08:56 AM
david-b's Avatar
Dave is THAT guy
Same thing I used. Found some bolts that fit into it which I believe Jason is right on the size, and then went to Ace and got some really long ones. It's actually not too bad. The puller itself you can rent. Buying it is only like $20 or so. Mine has already paid for itself twice lol.
75 Monte Carlo
Old 03-18-2010, 04:37 PM
Ok, got all the stuff you guys mentioned. Gonna try it all tonight. Do i use the impact wrench on the crank sprocket as well?
Old 03-18-2010, 07:38 PM
Ok, the crank sprocket came off WAY easier than id imagined it would lol. Took like 10 mins of fiddling with the puller and pieces....and it came right off the first time. Invaluable help guys!
Next, the 14mm and 9/16 was a tad too big, so i exchanged for a 13 and a 1/2, which fit perfect, so close enough lol.
Updates later!
Old 03-18-2010, 09:06 PM
david-b's Avatar
Dave is THAT guy
Nice nice. Glad it worked good. It's nice having people who've been there, done that before eh? Keep it going.
75 Monte Carlo
