Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 03-22-2007, 05:15 PM   #121
sam6632
Re: HOW TO: Remove Front/Rear Dash and Install Deck, Remove Door Panels
so anyway...back to the original topic of the thread. what is a GM tool for taking the door handle off when removing the door panels? im trying to replace my front speakers, but i can't get the damn door handle off. it doesnt have a horseshoe clip, so i can't just pop it off! what do i do, short of bashing it in with a hammer?
sam6632 is offline   Reply With Quote
Old 03-22-2007, 06:50 PM   #122
Derk_eliso
Derk_eliso's Avatar
Send a message via AIM to Derk_eliso Send a message via MSN to Derk_eliso Send a message via Yahoo to Derk_eliso
I didn't have the GM tool either, I just jammed a screwdriver in there, and then held it while jamming another in the other way, and I just kinda Jimmy Rigged it out... It broke and went flying across the garage, lol...
Derk_eliso is offline   Reply With Quote
Old 03-24-2007, 05:18 PM   #123
dray_jr
i am not even gonna cut it. if anything a shop can do it cause i am not lol. but it works fine usin the stock so ima keep it like this thanks for the tip thou
dray_jr is offline   Reply With Quote
Old 07-17-2007, 10:19 PM   #124
howling phantom
howling phantom's Avatar
Even tho this thread seems to be dead, i need a bit of help. Heres my situation. I get all the screws out, all of them including the brass ones(big pain). Ever thing seems to be going well, the dash is coming out on the drivers side, and then it strait stops. I wiggle a bit and work it side to side to no avail. I take a flash light to see in there and see 2 little clamp/hook things. These are what seems to be my problem. The thing is that I can get them to unhook. I try and try and I cant even see which way they come out, or even if thats my real problem. So, long story short, I need help. Anyone out there know what I need to do? Thanks
howling phantom is offline   Reply With Quote
Old 07-17-2007, 10:29 PM   #125
JStumpalump150
JStumpalump150's Avatar
2 hook thing? im not sure where your talking about so a pic would be great. i have taken my dash off like 20 times so i can probly help but need a pic.
2002 Nissan Sentra SE-R Spec V w/6 Speed Manual
JStumpalump150 is offline   Reply With Quote
Old 07-17-2007, 11:07 PM   #126
howling phantom
Well, i dont have acess to a camera right now, but im not even sure there clips. What ever they are, they are 2 black plastic looking things that have been insertet into a metal sheet that is tooth. The teeth prob keep the black plastic in there, but I dont think thats whats holding it on. I cant realy get a pic, but I can answer anything as I am looking at it right now. Any help you can give to get this dern thing off would be great.
Old 07-17-2007, 11:50 PM   #127
JStumpalump150
here are some pic i took a while ago, where at is the problem?
Old 07-17-2007, 11:53 PM   #128
JStumpalump150
from the discription of where your getting stuck it sounds like you didnt get the 2 gold brass bolts that you can access from the glove box, you may need a socket with an extention to get to them. i had that problem the first time i tryed to take off the dash.
if you look in the top left corner of the bottom pic in that black area thats where the 2 gold bolts are.
Old 07-18-2007, 12:15 AM   #129
howling phantom
I deffenelty got those brass screws out. Im pretty sure I got all of the screws, all of them. It just wont come out. Im so frustraited, it should come out. I dont know whats wrong, lol.
Old 07-19-2007, 07:49 PM   #130
howling phantom
Well, I feel retarded. I see now which brass screws you where talking about. Got them out and everything else went smooth as silk. Now I have a brand spankin new cd player and its thanks to you Stump, thanks bro.
Old 07-19-2007, 07:57 PM   #131
JStumpalump150
no problem,
i thought thats what you got hung up on cuz i was doing the exact same thing you were and getting pissed. i was yanking on the fucker to get it out then i looked on here and found i forgot 2 screws, lol. came out really easy after that. glad you figured it out.
Old 07-22-2007, 12:15 PM   #132
rmcracing
Is the glovebox a serviceable item? My 2001 came with a broken one. The plastic that holds the hinge mount completely broke away from the bottom of the glove box. I was thinking of going to a salvage yard and taking one out for mine, but from all the pics, it doesn't look like it will pop out with the removal of more clips and screws. Anyone taken one out before?
Thanks
rmcracing is offline   Reply With Quote
Old 07-22-2007, 12:22 PM   #133
Lances133
Lances133's Avatar
Send a message via AIM to Lances133
You should be able to just swap in a new one. Mine broke and I got a new one off ebay but the outer "cover" was a different color. I just unscrewed it and screwed on my original one.
Lances133 is offline   Reply With Quote
Old 07-22-2007, 01:32 PM   #134
rmcracing
Thanks,
Unfortunately, my problem is not just the door, but the whole interior box. Mine looks like a jagged shelf. From the pics I have seen, it looks like I need the whole lower half of the dash. From under the steering wheel, under the radio console and then the whole glovebox section all looks like one piece.
Old 07-22-2007, 01:44 PM   #135
Lances133
Lances133's Avatar
Ohh I see, then yes you will unfortunetly need the whole lower dash...that sucks.
