Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 06-17-2006, 11:55 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: Please Post D16A1 Swap Info Here
Originally Posted by pierce3381
ok i guess i'm a little confused... are the pistons in the 88-89 integra d16a1 the same ones that are in the civic zc 88-91? I alson noticed on an engine chart the d16a3 is rated at 118hp and the d16a1 is rated at 113 but it shows the d16a1 to be out of a 86-89 teg and the d16a3 to be out of an 88-89 teg? Just want to make sure i have the right pistons and rods before i start building the engine..
No matter what you read, ALL USDM '86-'89 Integra motors are labeled as a D16A1. There is no such motor as a D16A3, however the EDM versions of the DOHC D-series motors are labeled as D16A8 and D16A9.
The '88-'89 D16A1 pistons are the same as an '88-'91 Civic ZC.
Almost all of the internal parts are interchangeable between the DOHC D-series motors and the DOHC ZC motors, with the exception of the '86-'87 D16A1 oil pump and the Civic ZC crank and cam gears.
Old 06-18-2006, 03:42 AM
pierce3381 pierce3381 is offline
thanks! BTW your car looks awsome! Although I've had many many honda projects this is my first 1st gen so I'm trying to learn a little. I think my setup on the engine will be somewhat similar to yours as far as the parts go. I'll try to post some pics soon.
Old 04-18-2009, 10:30 AM
sweeteypetey sweeteypetey is offline
ok srry this is sorta off topic but i have a 3g civic, 84 civic 1500s hb. i dont know the engine code, for some reason it is very hard to find, but i am interested in a mini-me swap. i have done a little research and it looks like the D16Y8 will fit my engine block. im not 100% sure about that so, is there any other engine head that will fit my block and give my civic a little more kick? i would appreciate any info! thanks for looking
Old 04-28-2009, 04:49 PM
1gencrx86 1gencrx86 is offline
hey i need help i have d16a1 that im gonna put in a 87 crx do i have to change the distributor connetions and how
