| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#121 | |
![]() Join Date: Dec 2003
Re: B20 myths.
Well I'm just pulling this one out of my bum, but you probably won't need to resleeve for extra strength unless your going... over 10k? Does that sound right? Good R/S and walls on the B16 help, but I think it may cause premature wear on the engine
I would like to know this one myself as well, maybe someone can fill us in?But I would think you need extra cooling for a high reving engine as well. |
#122 | |
![]() Join Date: Mar 2004
Re: B20 myths.
thats what i figured. yes cooling would probley help. are the rods and crank different from the b16 to the b16b? they rev to 9k stock.
#123 | |
Re: B20 myths.
You know... why am I the one that looks for the answers... why dont you go search some?
#124 | ||
Re: Re: B20 myths.
#125 | |
I'm using a gsr tranny on my DOHC CRVtec and it works great. Actually I have it pulled right now to replace syncros and flywheel. But it has worked great so far.
#126 | |
Okay iam thinkin of gettin the b20 +b18c1 head , do u guys think id have a problem wiht the sleaves??? and if so i remmber seein some one say 10k for reslevin is that ture?!?!?
#127 | |
Re: B20 myths.
10k? Yeah right! The engine isn't even worth that much!
You shouldn't have problems with the stock sleeves unless your boosting. |
#128 | |
Re: B20 myths.
so what your saying is that if i resleeve it will be good as new?!?! no more problems with it ?!?!? because later on i plan to get a gen 3 turbo kkit
#129 | ||
Re: Re: B20 myths.
#130 | |
okay here are the parts i plan to put on my B20b
WISECO IB spec 12.5:1 pistons PROBE custom length rods Tit. wrist pins B16 pr3 head CROWER titanium valvetrain CROWER custom camshafts CROWER oversize in/ex valves NGK ignition wires DC Sports header w/mod 2.5 collector 3" cat back mandrel bent exhaust w/turbo black apex canister Fluidyne aluminum radiator HONDATA s100 system ITR intake manifold RC 310 Injectors AEBS fuel rail GS-R S80 Trans.(open diff.) ACT 6 puck clutch prothane bushings Endyn Breather kit cold air intake MSD external coil SUN auto Hyperground kit Oil Cooler/filter relocation Should i need to resleeve it??! |
#131 | |
Re: B20 myths.
If you are going to be doing some serious turbo charging, yes. A resleeve is essential relentless of its condition.
#132 | |
Re: B20 myths.
okay thank you mr 96civic
#133 | |
![]() Join Date: Aug 2004
sorry to bring up an old thread but if you are going to destroke the b20b go with atleast a b18c crank. a b16 crank in a b20b will not be 1.74 r/s, itll actually be 1.84, but you will need custom rods and you lose a lot of displacement. imo the crank should be left stock, longer rods will add more reciprocating weight, and the long stroke crank will allow for good displacement. remember rpm=faster wear on the motor. there is no need to destroke the motor to rev high, as long as you upgrade the necessary components(Rods, rod bolts, bearings, maybe a resleeve, and valvetrain) it will be fine. for example the formula atlantic/toyota 4age engine can rev to 11000rpm in built form, but has a r/s of 1.58; which is the same as the B18c.
#134 | ||
Re: Re: Re: B20 myths.
the B16A and B17A engines have a seperate block than all other DOHC B series engines, including the B16B. The deck heights themselves are different, thus, the b16b has a taller deck than the b16a, which means that it needs longer rods/taller pistons to achieve the same stroke. |
#135 | ||
Off playing with fire.
![]() Join Date: Mar 2001
Re: B20 myths.
Yes, definatly. It would only be a matter of time before the added compression from your 12:1 pistons blow out the walls. |
