| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
#121
Re: Lola T-70 Mk III
Fantastic work once again.
The client is not always right. - Enzo Ferrari ItalianHorses.net ![]() ![]() ![]()
#122
Thanks!
Reworked and assembled rear hub carriers. Brass tubing was added for the hinge points and open holes. ![]()
#123
I added two more "ears" to the front bulkhead for the front shock and upper control arm mounting points (per photos of real T-70s).
#124
Front upper control arms as they come in the kit.
#125
New fittings and bushings for the front pivot points. Machined aluminum & brass with steel reinforcements.
![]() Both arms with upgraded front bushings and adjusters.
#126
And new fittings for the rear pivot points, same construction as the front ones.
![]() Upper control arms dry fitted.
#127
I started drawing up the calipers. This is an inboard half. Still more details to be added.
#128
More details and the other (outer) side.
The rotors will be machined; I just wanted a blank to make sure it would all fit later. Now to make the pads... ![]()
#129
Brake Pads, more designing in SolidWorks…
Ready to send off to Fraxional for growing. ![]() ![]()
#130
The start of the aluminum rims. Some T6-6061 stock and a wooden angle block with 22 and 27 degree angles cut into it. The block was indexed to the tilt-table as a secondary measure to ensure the angles were uniform on all the wheels.
![]() First round of cutting; this will be a rear.
#131
This is a rear… Still raw and needs to be refined.
#132
Here are two rears and a front on the right.
#133
All five wheels, two rears and three fronts, (one for the spare).
#134
I added the radius/fillets and then polished them up.
![]() And a dry fitted front…
#135
I decided a more modern set of calipers would not only look cooler, but also be more appropriate for the car with some of the other upgrades it is getting. I made the Wilwood retrofits for the C3 Corvette calipers I made earlier. They use the same pads.
