#106
Re: just wont run right!!!!! 2001 cylinder 4 misfire
i just remembered when i was looking at the title on that car it said it was a v6.... i dont know if somebody switched vins or what on that car. theres no dout about it the ls's are very nice cars hell thers about a thousand just in my town alone there everywhere...
#107
Maybe they forgot to switch the ECU's from V6 to V8 & not tell anyone!
#108
Well Im getting p0307, 0171, and 0153 heavy misfiring, and some rattling noise.
Is the compression test the best way to check if a chain has jumped? Whats the best tester for these hemi heads?
Dennis 2003 Mach 1 2008 Expedition King Ranch 4x4 2010 Taurus Limited |
#109
Are you the new owner of this car?
If not, how many miles are on this car? A rattling noise could indicate a bad secondary cam chain tensioner, noisy cam followers, or amplified broken parts of a catalytic converter. A compression test is the best way to tell, if the cam to cam timing is off. I would focus on Bank2 (cylinders 4-7) on drivers side 1st. P0307 - Misfire on cylinder 7 P0171 - Lean code P0153 - Oxygen sensor on bank 2 1) When you pull the COP's on bank2, lable them 4,5,6, and 7. 2) Do a visual inspection for water, or oil contamination. The only evidence of water contamination is rust on the spark plug, or rubber COP boot. 3) Do a visual inspection on Spark plugs 4-7, and look close @ 7. 4) Do a compression test on all cylinders 4-7. 5) If compression is good on all four cylinders, clean the COP's, and connectors with CRC electric cleaner. 6) Roll COP # 7 with COP # 4. Note - All 3-DTC's could be a bad COP #7. |
#110
I don't think I'd jump to the coil yet. P0153 doesn't necessarily suggest that the O2 sensor is the problem. The possible causes for this code are as follows: contaminated HO2S, exhaust leaks, shorted/open wiring, improper fueling, MAF sensor, deteriorating HO2S sensor, or inlet air leaks. As you can see, many of these issues could be due to a lean condition on bank 2. Likewise, the P0171 code indicates bank 1 is running too lean. A bad coil will cause unburned fuel to get in the exhaust. This would not yield a lean code, but rather a rich code. A misfire can be due to an improper quantity of fuel as well.
It's worth swapping the coil from cylinder #7 to another cylinder to see if the misfire code follows the coil. I'd take it a step further and swap the spark plug from cylinder #7 with yet another cylinder. On the V8 it's not too bad to swap coils and plugs in case the misfire follows the spark plug. If it remains on cylinder #7 then I'd suspect the fuel injector. I'd also suggest cleaning the MAF sensor and carefully inspecting the vacuum lines. Is there a chance the rattling you're hearing is due to an exhaust leak? Does it seem more pronounced on one side of the engine bay than the other? -Rod |
#111
I will have to ask the wife how may miles are on it this evening but she has had it for several years.
Might can tell by how far back I have been posting on here. ![]() I swapped the coils earlier on #7 and no change. It however fixed the p0103 I had by changing it. I did put in new spark plugs on bank 2 and it got worse. I dont think its a exhaust leak, I think the sound I here is due to it loping so hard at idle. Been so cold here lately I haven't had a chance to go over it with my ear up close. But I thought I would buy a compression tester. Do I need one with a hose on it? I figure that is what it would take to reach that far unless they make one with a loooong rubber tip.
#112
You can borrow a compression testor from any Auto Parts store for a small deposit.
1) Try to isolate noise to bank 1 (cylinders 1-4), or bank 2 (cylinders 5-8). 2) A Local muffler shop can do a back pressure test on your catalytic converters. Physical cylinder assignment- Tran 4 8 3 7 2 6 1 5 FAN The Lincoln LS & Jaguar S type are like bad sisters! see http://www.automotiveforums.com/vbul...d.php?t=954555 |
#113
Any chance your wife just put bad fuel in it, like 87 octane or something?
-Rod |
#114
I wished. ![]() This has been a problem longer than that. Found a tester on amazon I may buy. Only reason I want to check compression is so I dont spend money on injectors and cant return them if their not the problem. Will try to do a ear test this weekend. God I hate winter.
#115
It can't hurt to put some octane boost in the tank!
If you have Injector problems, you can do a ''Out of car Injector service'' any local diesel shop can micro bath, blow out, test flow rate, and put new injector seals on for $20-$25 per injector. Just because you got a signal, clicking sound, or resistance doesn't tell me that the flow rate is good. You could try rolling the injector, if bad, just do the cleaning on the one injector. I have taken known bad injectors for a good cleaning, and they were good. |
#116
Saturday just for the hell of it I took the first 3 injector connectors off on the drivers side and it didn't make any difference in the missing.
![]() Put in a new fuel filter while I had the time. But is there a way to have my injectors cleaned if I remove them? Is that a dealer job, or a local mechanic? EDIT: Well Ill be, there is a ton of videos on cleaning them yourself. Looks simple enough.
Dennis 2003 Mach 1 2008 Expedition King Ranch 4x4 2010 Taurus Limited Last edited by 34Ford; 01-31-2011 at 01:19 PM. Reason: self cleaning |
#117
Any local diesel shop can clean bad injectors.
#118
Wonder if these are worth the money? OTC -7448 Fuel Injector Cleaner.
Theres videos of it in action on youtube. http://www.amazon.com/OTC-7448-Fuel-.../dp/B0002SR60W
#119
You gotta listen to this this thing rattle. Now remember this is happening while its missing like the dickens.
http://www.youtube.com/watch?v=rBxY0iJ_Tu0
#120
Yeah, something's definitely not right. I guess you should first confirm the rattle is not in one of the belt pulleys, but since you also have a misfire, chances are good the rattle is related. Hopefully it's not due to a lack of compression.
-Rod |
