| WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
#106
Re: Promocom Toy group Ferrari 126C2 scale 1:8
speechless. Bellissima Tony.
Paolo - LoveGT40 Modelworks website www.alsoldatino.com my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber FB: https://www.facebook.com/alsoldatino |
#107
Lovely work Tony!
Lee. |
#108
Thanks guys!
#109
All very good but did you saw your finger.
#110
No, I flipped my thumb nail
...and the bandage is to keep it in position. But it could have happened !Ton |
#111
![]() ........what is this, an empty engine stand? :mrgreen: Yes!!!! This afternoon the "marriage" of engine and monocoque was there ![]() the "ceremony" took a long time because both parties were not very willing ![]() The holes which were drilled by the manufacturer did not correspond with the attachment points on the engine. So I drilled new holes and added a thread ![]() .....and than it went perfect ![]() and here an overall look regards Ton |
#112
An update with a few small parts, but first I put the car on wheels to see if it is "straight". Don't forget that the front and rear suspension are missing parts replaced by me
![]() ![]() ![]() I am satisfied for 99,9% .....I have to make some adjustments and the wheel base has a small deviation. I thought that I finally left all the problems with missing or wrong parts behind me but......I found out that one of the aluminum front rim has the right outer part but the inner part is from the rear rim!! Now I have to cutout a 2.5 mm slice from the aft inner part and glue the parts with epoxy together But now it is time for the mesh for the air inlets of the engine. ![]() The mesh of the kit is looking terrible so I decided to use some 1:43 mesh from Tameo. It is rather rigid and hard to shape ![]() I used a punch with a ball head and I folded the mesh around it. ![]() The rim is secured with epoxy glue which hardened for 36 hours. I removed the remains of the mesh with a grinding wheel ![]() The un-assembled result ![]() and the assembled one. You can also see some reinforcements between engine and monocoque. Now comes the time where I need my solder station to assemble the cowling sections. ![]() Ton |
#113
This update shows the building of the cooling system en some "unknown systems"
![]() The main cooler for the turbos are made out of PE and white metal. ![]() The bracket needs to be positioned very carefully, luckily there are some adjustment points ![]() The coolers are finished and weathered ![]() This bunch of PE should become another cooler. I love soldering :mrgreen: ![]() And a few hours later the whole lot is done ![]() It took so long because I had to put 128 louvres to 4 racks! ![]() Because the gaps between the louvres are about 0.5 mm I decided to solder and glue them (solder-glue-solder- and so on) ![]() ![]() ....and it looks very nice ![]() ......until it drops and the glue joints are less strong than the solder joints ![]() and here are the "unknown devices" by Magneti Marelli ![]() The right device is something electric ( white parts are plugs) but the other two......I really don't know. I googled Magneti Marelli but It haven't seen anything that looks like one of the devices......so if anybody has a clue! ![]() devices are finished ![]() And this shows the three parts together. I will position them to the monocoque after I have fitted the carbon underside: If I don't do that I am afraid I have no room for a proper fit of the underside. |
#114
Taking shape nicely Tony, looks fun putting the photo etch together!
Lee. |
