Old 09-01-2018, 12:07 PM   #106
Scale-Master
Scale-Master's Avatar
Re: LHD Seven
After Swiss cheesing the dash I reinforced it on the back (front?) with .020 x .070 thick strips before risking a fracture.
Scale-Master is offline   Reply With Quote
Old 09-05-2018, 03:11 PM   #107
Scale-Master
Re: LHD Seven
The gauges will be Auto Meter brand. I started off with the tach and speedo and a small vacuum gauge.
They are milled so the lenses will mount from the inside like the real ones.
Old 09-06-2018, 11:55 AM   #108
Scale-Master
Re: LHD Seven
The water temp, oil pressure, volts and fuel housings were roughed out next…
Old 09-06-2018, 12:24 PM   #109
360spider
360spider's Avatar
Re: LHD Seven
That's how it was when cars were not run by computers - lots of gauges!
ItalianHorses.net
360spider is offline   Reply With Quote
Old 10-05-2018, 06:41 PM   #110
Scale-Master
Re: LHD Seven
I made the needles for each gauge. They are different sizes and proportions because the gauges are three different sizes and two of the mid-sized ones are electrical and two are mechanical. (They are really small.)
Old 10-05-2018, 08:46 PM   #111
Scale-Master
Re: LHD Seven
These are the lenses I made for the gauges. The one for the vacuum gauge lens is already installed. The hole in the one is for the reset knob for the trip meter.
Old 10-05-2018, 11:09 PM   #112
Scale-Master
Re: LHD Seven
These are the gauge faces. I machined the parts and drew the art and printed them out. The needles are mounted to shafts (like real ones).
Old 10-06-2018, 08:19 PM   #113
freakray
AF Modelrater
Re: LHD Seven
As much as I know the scale, would love to see a coin or something alongside to give perspective. Your work is immaculate and I think true appreciation would be given if there was something for scale.
Personally, I can only dream of having your skills!
AF User Guidelines
freakray is offline   Reply With Quote
Old 10-07-2018, 03:23 PM   #114
Scale-Master
Re: LHD Seven
Thank you Ray! Next post I'll include "the big ruler".
The reset knob for the trip odometer. Three pieces.
The largest part of it is .030 in diameter and has the ribs machined into it.
Old 10-08-2018, 01:12 PM   #115
Scale-Master
Re: LHD Seven
The gauges are done for now and loosely fitted to the dash.
Old 10-08-2018, 08:39 PM   #116
freakray
AF Modelrater
Re: LHD Seven
See, now that ruler gives the size a whole new perspective and makes the detail even more impressive! I have no idea how you work with pieces that small, I am completely in awe!
AF User Guidelines
Old 10-08-2018, 09:38 PM   #117
360spider
360spider's Avatar
Re: LHD Seven
Very impressive set of gauges!
ItalianHorses.net
Old 10-09-2018, 02:11 PM   #118
Scale-Master
Re: LHD Seven
Thanks guys!
I started machining the switches for lights, blinkers, key, starter and windshield wipers.
Old 10-10-2018, 07:57 PM   #119
Scale-Master
Re: LHD Seven
Key switch for the ignition is done.
Old 10-12-2018, 05:55 AM   #120
is200_adelaide
is200_adelaide's Avatar
Re: LHD Seven
love the attention to detail with that dash! I'm guessing you're going to make a key too?
is200_adelaide is offline   Reply With Quote
