Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 04-21-2005, 03:51 AM
MikeMan MikeMan is offline
Banned
Send a message via ICQ to MikeMan
Yep, it fits alright. Just don't expect to be able to see the sides of the engine, and make sure you run some petroleum jelly up the sides of the engine bay when you're trying to squeeze her in.
Seriously though, I'm 95% complete on my project, so if you have any questions whatsoever on the swap, feel free to drop me an email or PM or something.
-Mike
Old 04-21-2005, 04:05 AM
Zgringo Zgringo is offline
Good to see you Mike..
I use petroleum jelley for other things than installing engines.
What do you mean it's a tight squeeze in the Z31. It isn't much better in the Z32.
Old 04-21-2005, 04:10 AM
Banned
Re: Twin Turbo Swap... READ
Well I don't know about the z32, but I can't fit my hand between my rocker covers and the engine bay wall.
Old 06-08-2005, 06:08 PM
b18chic b18chic is offline
Hello all....well here it goes. I was on yahoo looking for a wiring harness for my friends 1994 300zx motor. We are currently in the process of doing a TT swap into his convertable NA 300z. The most we have done at this point is putting the new TT motor in his car, but in the process of exchanging the motors some how the wiring harness off his old NA motor was lost or stolen. So now I am stuck with the task of finding a wiring harness for his car. Does anyone here know of any place that I could find one? Also what do you do about the intercooler? Where do you find an intercooler with two inlets on each side? Also is there any pertinate info that you would give to me that would help in this project? I am sure people have asked this eariler in this thread but unfortunatly I don't have time to read all 7 pages worth of this thread. Any help will be greatly appreciated!!
Old 06-08-2005, 06:25 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
well you have completed the easiest step of the TT swap, swapping the motors. now, you have to pull the motor back out!!!
i do not see how there is any way possible for you to install the EFI harness with the engine in the car. here are some places to look...
http://www.amzperformance.com (check the OEM parts list)
http://www.conceptzperformance.com
http://www.z1motorsports.com
if you want to go cheap and take a chance...
http://www.twinturbo.net (go to the classified section and start a new post or search through)
it sounds like you dont really have a clue on what parts you need to complete the swap. i would search around on twinturbo.net and z1motorsports has a winderful write-up that explains what your getting yourself into.
just a list, make sure you have these parts...
-AC lines (if you want AC)
-TT transmission
-TT flywheel
-TT clutch & pressure plate
-AC condensor (if you want AC)
-N/A power steering pump
-AC compressor (if it is a JDM motor & you want AC)
-Boost controller (unless you buy a TT EFI harness)
-TT ECU
-Boost piping (from turbos to intercooler to TB)
-intake pipes (from intake to Turbos)
-TT radiator and upper radiator mounts*
-TT upper radiator hose
-pilot bushing (if you bought a TT motor out of an automatic car)
-TT half shaft or a custom driveshaft
-N/A speed sensor (tranmission specific)
-intercoolers, ducts, and brackets
-oil cooler and lines
-if you bought a JDM motor, you can use the stock N/A midpipes
-if you bought a USDM motor you will need TT midpipes to connect to the downpipes
*to put in the TT AC condensor and TT radiator you will need to customize the lower supports because they are narrower but taller than the N/A pieces. so the TT radiator sits farther down in the bay than the N/A to let the boost piping go on the side of it.
if you have any questions, start a thread and post or PM me...i am doing a TT/5-speed swap as we speak and i can more than likely take pictures for reference or verbally help you.
good luck!!! hope you know what you have gotten yourself into.
BTW: how in the hell did you lose the efi harness??? it shouldnt even have been removed from the car.
ZedEx Crew Member #4
Old 06-15-2005, 01:33 AM
masood masood is offline
Send a message via ICQ to masood Send a message via AIM to masood Send a message via MSN to masood Send a message via Yahoo to masood
man.. i'd rather sell the car and buy a TT.. it will cost you more than buying a tt car.here in CA cost around $5600 to convert it to a TT... go to racycler.com and get a TT
Old 06-15-2005, 03:18 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
sometimes it's not about just knowing you own a fast car, sometimes it's about knowing you put sweat tears and blood building the car to make it as fast as it is. or there's times where it's more expensive to buy a tt car than to convert one to tt (in my example, in order to get a tt for a perfect body, i'm looking at over 16 grand, where i could find an n/a with a bad engine and perfect body for between 4200 and 6400. now factor in it Just being the engine swap... no tranny, no nothing, just the engine, wiring and ecu (other stuff necessary of course) which i could find on ebay (again just the engine) for a little over 1500. i do all the work myself, now i've got a tt with a perfect body for 8-9 grand.
i guess it just depends on availability.... up in canada, any z car is hard to come by
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-15-2005, 11:46 AM
Z Cars Fanatic
the only reason why i am doing a TT/5-speed swap is because my N/A is in mint condition with a fresh paint job and some minor body work. plus, i want to belong to an even rarer club by having a 2+2 TT. in some peoples position it is better off to perform a TT swap.
i would need to find a mint condition TT with a fresh paint job, 25k miles on the motor and 95k on the body. also, needs to have a JDM front fascia and a mint condition interior with a very nice stereo. i think that would be hard for me to come by for $10.5k and thats about what i have put into my car, and thats including upgrading the motor to 475 hp.
Old 01-21-2006, 05:47 PM
Japanese engine Racing JER in S. CA will swap the RB26DETT for $10,000 . they are working now on two old Zs 260z and 280z. almost done. will take pictures for you guys
Old 05-21-2006, 03:48 PM
PirateKingofCuba PirateKingofCuba is offline
ditto. after looking at this, I'm thinking I may just go buy a camry and a crotch rocket.
-Will
Old 06-05-2006, 02:44 PM
Z Cars Fanatic
-Will
wuss...what would be the fun in that? part of owning a Z is the modifying part. Z's + good owner = money pit for the owner because he or she will modify till their pockets are completely empty. its what makes Z ownership, Z ownership.
Old 06-05-2006, 09:44 PM
DeleriousZ's Avatar
f'n expensive z's... mine will ruin me before the year's out...
Old 06-05-2006, 10:29 PM
Z Cars Fanatic
lets not even talk about it...
Old 06-05-2006, 10:37 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Z's suck.
I'm on my second one.
It's definately a love/hate relationship.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 06-05-2006, 11:27 PM
Z Cars Fanatic
Originally Posted by -The Stig-
Z's suck.
i have hated more than loved, but i cannot deny the love.
mine has been sitting since february of 05'. all for some upgrades...
