Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 03-08-2005, 09:02 AM
jamey240 jamey240 is offline
Send a message via Yahoo to jamey240
Re: Re: RB SWAP FAQ FROM UNSTABLE. GOT AN RB QUESTION? LOOK HERE FIRST!
cool, you dont know of anyone who makes a wide body kit for the car do you?
Old 03-08-2005, 07:37 PM
i like the idea of the twin turbo, can the rb25 be turned into a tt? what kind of steps should i do to do such a thing? the mechanic i am talking to is pushing me to the rb25 too, says with the 26tt, that one of the turbos is pressed against the firewall. rattles, and threatens fire on the otherside of said firewall. and that there is a lot of cutting required.
Old 03-12-2005, 01:23 AM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
TT is no better than single turbo. Single turbo is much more simple and leaves you much more underhood room. Less heat as well.
This car is no different than any other car. To make more power, you must put more air through the engine with enough fuel and you must ignite the AF mix at the correct time.
I hope you realize that 500whp in a 240 is useless on the street.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 03-16-2005, 01:58 PM
dosent the tt setup stop the idea of 'turbo lag' by having one turbo spooled faster and therefore outputting more power sooner and then when that one is wound out, the second kick in?
& yeah, i know 500 whp is useless on the street (do you think a viper owner thinks that too? (i used to have a 96 z28 six speed and came across a viper (or rather the viper came across me) that just totally walked away from me like i was standing still) ... but it sure does make fun for shits n giggles.
Old 03-17-2005, 06:53 PM
240SX Guy
You're thinking of sequential turbos. Preference really. But go to phatka-t.com and watch a couple of thier vids. Mainly the 500whp on the street and tell me they have lag.
A viper is much heavier than a 240 so wheelspin is not so much an issue.
-Cory
12.6@122mph
Old 03-22-2005, 11:08 AM
those vid's are insane! i like..... any other sites anyone could recommend for research purposes?????
Old 03-23-2005, 08:04 PM
240SX Guy
www.ka-t.org
www.nicoclub.com
www.240sxforums.com
www.freshalloy.com
I believe all of them have video sections. I usually go to ka-t.org, nicoclub.com, and phatka-t.com. All really cool guys. This one is the best though:
http://www.team-octane.net/turbokaultimate.zip
-Cory
12.6@122mph
Old 04-10-2005, 07:47 AM
Eleanor NL Eleanor NL is offline
I've been reading this complete guide (it's great!)
but i still have a question rewgarding the RB25 swap.
here in europe, the 240sx's are standard equiped with a SR20DET engine.
is it worth swapping it to a RB25, or should i put all my money in the tuning of the SR20DET?
Old 04-10-2005, 01:12 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Tune the SR and stop posting questions in the Stickies.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 04-14-2005, 12:26 PM
gadco gadco is offline
i have a rb26dett on my 1990 240sx. im getting backpressure on my turbos as soon as the blowoff valve close. i can feel and hear air coming out of the filters. somebody have an idea may i need to install another blow off valve?
Old 04-14-2005, 04:19 PM
Sounds like the spring is to stiff.
-Jonathan
Montreal, Canada
Old 06-21-2005, 06:13 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Common occurance on tuned RB26DETT's, HKS even make an air flow meter idle computer(exact name unsure) to compensate for this air reversion.
BOV spring pressure helps but it is a pain when your Air Flow Meters get so much air rushing past them your engine stalls
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 05-31-2006, 11:42 PM
infinous infinous is offline
For those of you that are interested in swapping out for a rb26dett motor i would like to maake a suggestion. First off i would suggest that you go with a Rb25det first and foremost because of the way the engine would have to be installed to fit both turbos is way to pricey! secondly for about what it would take to install a 26 you could pull out almost twice the power out of the 25 and have it much more reliable. installing a rb 26dett correctly you are looking in the ball park of about ten grand doing it yourself as aposed to the 6 grand for a 25 if you were to do it yourself! In the end that is m opinion and just a suggestion. the typical reason someone would install a rb 26 motor is just to say hey i jst spent a ungodly amount and got a stock twin turbo skyline motor. But to each his own.
Old 06-01-2006, 02:52 AM
David_NISMO David_NISMO is offline
True True, all True.
But I wouldn't take back my rough idling, badly tuned, rb26 swap even though I spent over 8K on the swap. The look on people's faces when they see that motor is priceless.
In the end though, my car would be twice as fast as it stands now if I went with the RB25 route. But I'm hoping that the potential for HP down the line will outweigh the cheaper initial cost of the RB25. They are similar motors, but still, so very very different.
Rolling in a power by a
Old 07-27-2006, 03:54 AM
Keener305 Keener305 is offline
ok this is a lil old post but hopefully ill get a response... im planing on makin the RB26 swap... if i got the engine... got the car... yada yada... tranny... how much would it cost to JUST get it put in so it fits
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0 Jay! Car Modeling 49 08-24-2010 07:15 PM
Got a tech question? Check here first! nissanfanatic Technical 5 01-25-2006 04:53 AM
AF Die-Cast Modeling FAQ- *Look Here First* mike@af Diecast Car Modeling 14 09-05-2004 02:55 PM
AF Car Modeling FAQ - * Look here first! * Jay! Car Modeling 0 05-10-2002 09:13 PM
If you found out about AF from Sport Compact Car look here igor@af Hot and Not 26 05-09-2002 06:49 AM
