Old 06-09-2011, 05:49 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: 2000 3.8-Neutral SftySw-Is this the shaft?
kafkacell and WindstarMommy, I don't think you're talking about the same oil leak. Kafkacell, you seem to talk about the oil leak of Mark Gober's friend's taurus in 2nd pic.
WindstarMommy, there's ways to find out if it's leaking trans fluid or engine oil. You can either clean off the leak, put a dye in engine oil and see the leak later with an UV light, if it's engine oil you will see the dye in the leak. That's the professional way.
The simpler way: touch a drop of the leaky oil with your finger and feel the viscosity, smell the oil and check the color. If it smells very strong and bad, it's not that viscous, and it's a little bit red (could also be brown/black) it's trand fluid. If it smells dirty oil (softer smell) and it's very viscous, it's engine oil. You can smell your actual trans fluid and oil to compare.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
The Following User Says Thank You to serge_saati For This Useful Post:
WindstarMommy (06-10-2011)
  #77
Old 06-09-2011, 05:51 PM
kafkacell kafkacell is offline
Fooling around
Wow my bad... I was reading WindstarMommy and thought she was gonna put pictures of the process too. But Mark did. But in any case mommy should check for leaks in that particular point.
Hyundai Elantra 2001 GLS
YOU ONLY
NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND
SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
Old 06-10-2011, 09:16 AM
WindstarMommy WindstarMommy is offline
Originally Posted by serge_saati View Post
kafkacell and WindstarMommy, I don't think you're talking about the same oil leak. Kafkacell, you seem to talk about the oil leak of Mark Gober's friend's taurus in 2nd pic..
Hi, serge - That's what I was thinking.
Thanks, again kafkacell! I was going crazeeeee trying to see in my photos that leak...LOL! Whew! The pics that I did put up were in links. I am not that skilled to put up actual pics on the posts yet.
I went out this morning and unplugged the cable to the TRS and plugged it back in. The check engine light disappeared but I haven't driven her yet.
The saga continues...
Tags
alignment , neutral , safety , switch , trs
