| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#61 | |
調整器
Re: b16a1 swap question
i'm using the obd-1 p28 ecu, but my B18 is obd-0
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
#62 | |
OBD-0 Injectors will work too, just wire in the resistor box when you're using an OBD-1 ECU. Sometimes, if you get to a junkyard that has them, you can get resistor boxes and Main Relays free... I get them free around here sometimes.
Honda-free since early 2009.Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win. |
#63 | |
Well if your car has a resistor box right now just leave it in the wiring, and use the obd0 injectors. They are all 240cc and will work fine.
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
#64 | |
Hrm... why didn't I realize that the OBD-0 B18 came out of his car.. and therefore most likely used a resistor box.. damn I'm stupid this early in the morning.
#65 | |
TLD Member #1
Frodo nailed it.
Adrian nice decoy post....except I can only assume the 6 digit number on the bottom left of the valve cover is the mileage on it....you were close :P
Tony 91 Civic Sedan DX - Stock 287k Miles |
#66 | |
調整器
i think that's 7 #'s...after the 5 there's a zero....but the engine did say B16a, i just used paint to copy the 1 from those numbers to make it B16a1
![]() alright...happy i can use those injectors
#67 | |
調整器
well, just waiting to get everything wired up
#68 | |
There is no Spoon
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2002
Bad ass man. And damn is that thing clean!
#69 | |
調整器
i got the valve cover yesterday...made it look a lot better
#70 | |
I liked the red one, but for safety's sake, black is probably the best way to go, especially if you ever plan on opening your hood outside of a locked/hermetically sealed garage.
#71 | |
PS.. Did you paint that intake, or did it come that way? And is it aluminum?
#72 | |
調整器
yeah it's aluminum and came that way...ebay special
upon stripping the red valve cover i round out it was damaged...dent in the front that cracked through to the inside
#73 | |
Oh, that sucks.. can't even sell it then. I figured you just changed it for the sake of it being a CTR cam cover...
#74 | |
調整器
well i did. but i'm glad i found this out
#75 | |
調整器
IT LIVES but the distributor is bad
