Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-04-2005, 02:01 AM
SMOKYHIKER SMOKYHIKER is offline
V6
87,000
Ping,Ping,Ping no matter what I do.
Check engine light-Cleaned EGR after advice from this board.So far light is still out!
Rear brake pads at 87,000. Still on original front pads and rotors but need replacements soon.
S belt
Change my oil at home every 4000-4500.
Old 06-04-2005, 02:06 PM
matt95gsr matt95gsr is offline
Re: How many miles do you have your Isuzu?
1997 "Passport"
3.2 V-6
98,000
timing belt, water pump, starter, rear passenger window regulator, brake pads, mass air flow, gonna pick up new alternator today.
Old 06-05-2005, 12:40 AM
witherer witherer is offline
1994 3.2L V6, 161,000
CV Boots, alternator, re-grease 4x4 hubs, rotors re-faced, Sea Foam treatment for ticking, replaced starter
Old 06-06-2005, 12:52 AM
KurtAZ KurtAZ is offline
1995 Passport
179,659 miles and still going.
Old 06-16-2005, 01:14 AM
perry8685 perry8685 is offline
Send a message via AIM to perry8685
Exclamation
Year:1994
Dee Shiznit, Something's Wrong! I Think. Um but maybe not!
Old 06-16-2005, 01:28 AM
Exclamation
Year:1994
Engine:3.2L V6
Mileage:114,500
Major Problems:
Fuel Pump Failure! The reason I consider this a big issue is the fact that I had just replaced the fuel tank due to the fact that someone wedged their car under my rear and crushed it! When this happened the Insurance adjuster decided the pump was fine, which it was but with 105,000 miles on the vehicle who's to say it won't go any day?! I reached 112,000 and it went a couple miles later Oh well,
but the real problem is when you have a "HIDDEN???" trailer hitch and the tank has problems dropping below it. Yeah I had to do this with a hydraulic auto jack, a board and my two hands to drop the tank beyond the hitch and reach the fuel pump! Don't forget about the tiny spaces in which you have to reach the little fuel lines and connections in order to do this job.
Anyway,
don't mind my rambling I just have a "short wick" when it comes to fuel tanks and pumps on Isuzu Rodeos with "HIDDEN???" trailer hitches!!!
Hope it never happens to you
Perry
Old 06-16-2005, 08:17 PM
NJFrank NJFrank is offline
Year: 96
Motor: 3.2
Mileage: 125k
Major Problems: None so far
Minor Problems Past:
Starter Motor
Rear axle seal driver side (while under warrenty)
trans sensor (while under Warrenty)
Current issues (no time to fix)
Passenger side window regulater
4x4 won't engage
Dash Lights not working
Famous valave ticking sound (have to spend more time playing w different filters)
All above seem to minor fixes, just need the time to address them.
Old 06-24-2005, 09:07 AM
D-FOSSE's Avatar
D-FOSSE D-FOSSE is offline
Send a message via Yahoo to D-FOSSE
95
3.2 v6 4x4
120k
excesive cranking to start, reverse problems when in 4x4
Old 06-30-2005, 01:31 AM
bighops2000 bighops2000 is offline
Send a message via AIM to bighops2000 Send a message via Yahoo to bighops2000
JUST TURNED 165K no serious problems. plan on keeping until the wheels fall off
Old 07-06-2005, 11:24 AM
dea2650 dea2650 is offline
Rodeo's are the best:
1995.5 Rodeo 4x4
195,000 miles
My first and only new vehicle. This vehicle has never left me stranded, even when the alternator finally went out at 150,000 it still had enough juice to get me home. Wish I could keep it forever!
Old 07-14-2005, 10:00 AM
Trigggl's Avatar
Trigggl Trigggl is offline
Year: 1997
Engine: 2.6L 4cyl
Mileage: around 130K
Any major problems: Had to replace the clutch after around 60K. Bought it at 50K. (used cars ) Had to replace the fan clutch at about 75K. Got the timing belt and water pump while I was at it. Electric EGR valve went bad at a price of $150. Rear suspension is very weak. Steering is really loose. Had to replace some dash lights. Can a brother get a second cup holder and rear speaker cabinets big enough for 6x9's?! How about 5x7's? My escort had bigger speakers.
Old 07-15-2005, 05:30 PM
hazegrey hazegrey is offline
Miles: 99,500
Had valve cover gaskets replaced at 65,000 (still leaks go figure) 3 alternators and 2 sets of brakes. Timing beat tensioner is going out as well as the carrier bearing but no major problems yet.
97 RODEO LS 2WD 121K mi
08 Saturn Outlook FWD XE
Old 07-31-2005, 08:08 PM
cubigman cubigman is offline
1993 Rodeo V6 4wd
228,000
No major problems
It just keep on ticking!!!
Old 07-31-2005, 10:58 PM
shakagg shakagg is offline
1999 Rodeo
V6 3.2
151,000
No major problems.
Has the usual fuel sending unit failure and oil consumption complaint.
Taking it in next week for timing belt, water pump and tensioner swap.
Old 08-09-2005, 06:38 PM
97Rodeo 97Rodeo is offline
3.2L
214,000
Major tune-ups as required, tires, brakes.
No major problems!
