| View Poll Results: What HIGHWAY gas mileage do you get in your Chevy 1500 series truck? | |||
| 26 mpg or better Highway mileage |
10 | 1.65% |
| 24 mpg or more |
6 | 0.99% |
| 22 mpg or more |
17 | 2.81% |
| 20 mpg or more |
74 | 12.21% |
| 18 mpg or more |
133 | 21.95% |
| 16 mpg or more |
159 | 26.24% |
| 14 mpg or more |
116 | 19.14% |
| 12 mpg or more |
62 | 10.23% |
| 10 mpg or more |
19 | 3.14% |
| Less than 10 mpg Highway mileage |
10 | 1.65% |
| Voters: 606. You may not vote on this poll | |||
#61
Re: GAS Mileage - how to make it better.
I have a 99 silverado wiht the 4.3 vortec and a 5 spd stick with the 8 ft bed, depending on how I drive and the weather conditions i get anywhere form 900 to 1200 kms per tank of fuel. I have a 128 liter tank I think thats about 33 gallons. so its about 23 mpg or for the canadians out there around 10 liters per 100 km
#62
Running on propane i got 11.8 mpg, at a cost of 7 cents per mile, I just run out of propane and switched to a full tank of gas, give me a while to see what cost I get...
Re: Re: GAS Mileage - how to make it better.
I take it you have a vehicle with the "gas tank" mounted in the truck bed and you have a customized engine for burning propane ????? I thought those units then didn't have the ability to use gasoline anymore. Can you give us a bit more of a description of your vehicle configuration? White Lightening |
#64
Well, the system is setup to run on either gasoline or propane, by the flip of a switch, I can be running on propane at 60mph and flip the switch, the truck will loose power like if I let go of the gas pedal, and 2 seconds later you will feel the engine literally "kick in" with the other fuel. The system addons are:
1 OBD II controller PN 5929 from Dual Curve 1 IMPCO mixer 1 IMPCO gas pressure regulator 1 propane filter 1 200 liter gas tank (you can get them smaller, I wanted the autonomy of running 1,500 miles or more without seeing a gas station). 1 Dashboard selector switch 1 fuel sending unit (so the propane gas level will read out on the stock dash fuel gage indicator) hoses, fittings and bla bla bla. The OBD II controller will modify the timing and monitor/control the fuel ratio while running on propane, I installed a fuel ratio gage just as a precaution to see if the controller crapped out and I was sending to rich a mixture into the engine, this never happened. Flip the switch and open up the mixer throttle body with the lever (in the picture the switch is behind the lever) to function with gasoline, when I do this the fuel pump in the tank turns on, the inyectors turn on and a shut off valve cuts off the propane. The OBD II controller also bypasses so your PCM will revert the timing back to work on gasoline. On the picture looking into the hood there is a lot of contrast from the sun (lower 60's today, sorry about that you snow buried northeners). Flip the switch again to shut down the pump & inyectors and turn on the 5929 controller, propane flows thru the shut off valve, goes into the pressure regulator which lowers the pressure from 300some psi down to ONE psi (coolant lines run through the regulator so it doesnŽt freeze) and from there it goes to the throtle body thru a 1.5 inch hose to the top of the mixer (serves as a carburator) that replaces your stock housing right on top of the throttle body. The idle mix is controlled in the mixer with a servo and the full throttle mix is controlled on the regulator (you can see the two wire harness going into the regulator). Fun ainŽt it! The last picture I just took it because the cloud over the mountain looked awesome. ![]() ![]() ![]() ![]()
I have a question... I'm suspecting that my cats are stopping up, but I dunno how to prove it. My mileage has went down over the last few months, even before my tune, and it seeme like it used to have more power....is there any way to make sure they are stopping up before I cut them? This will also make me loose some low-end power if I eliminate them?
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
#66
If you are going to eliminate them, take the whole catback off the truck, and go in through the top of the cat by cutting along the length of the cat and take the guts out, then close it up again. It will pass inspection (theyŽll see the canisters) and youŽll get the extra power!
I don't have inspection here
never have, hopefully never will. This is the first vehicle I've left the cats on. I just wanna know if I do cut them off, will my low end torque suffer....I don't want that.
1998 ECSB Z71
#68
It seems as though many truck owners in this forum spend hundreds even thousands of dollars modifying their pickup to save a few mpg. Is it really worth it? I am looking at doing some mods to my 2002 Z71 (air intake, exhaust, programmer)...but I am doing it for the extra HP-better mpg will just be a biproduct. How much will you have to save at the pump to recoup all the money spent on improving mpg? Just a thought.
#69
I can understand your viewpoint, but I think you may be missing a more important reasoning for fuel savings. When you look at machinery - whether it is a truck engine or a metal lathe or a table saw - the less resistance you have to "spin it", the more efficient it operates. Because it operates more efficiently - it also maximizes its power abilities (within reason). What I think you're seeing by many of the posters here - is they are working at ways to improve lubrication, improve performance, and reduce "drag" issues. All that - shows up in improved gas mileage and improved vehicle longevity in my opinion - and it also gives you better performance. It doesn't mean the effort is ONLY about saving an extra gallon or two a week (or 3 or 4 or 5) - the MPG is a measuring device also - measuring how efficiently your engine is operating. Take your own engine/truck - find methods of increasing its MPG - and the chances are - it will lengthen the usable life of your engine/truck also. To put it another way. If I'm "capable" of walking 5 miles a day - and then I work on being able to walk 10 miles a day - chances are - the "ability" to improve will mean I'll be much healthier in the long run. Just my viewpoint. White Lightening |
#70
Looks like I have to get a S10. |
#71
Anybody hear how the 2005's are for gas mileage compared to prior years? Any technology improvements?
#72
#73
Re: Re: Re: GAS Mileage - how to make it better.
Maybe change your gears to 3.42. |
#74
I'm really surprised that your Z71 would have a 4.10 axle ratio. That is what they use in the SS because it gives better "redlight" quick-off-the-line performance. It also effects the gas mileage too. What you can do from present? First thing - you can make sure you have a tonneau cover - as this changes wind resistance. I have a HARD but folding unit (folds to 4 sections) - and it improved my mileage by 2 mpg on the highway. Also my experience is that if you break the truck in properly - you will notice improved gas mileage after the first 5,000 to 10,000 miles. the thread also mentions a number of other ideas (using slick 50, airhog air filter, premium gas, etc.). White Lightening |
#75
Thanks
Thanks for the advice, I check into the things you listed. I think there are quite a few 4.10's running around in the 2005's. When I was told that it would get the same gas mileage as the 3.73 I fell hook, line, and sinker. I did call Cheverolet and they said the truck could break in between 5000-7000 miles. *fingers crossed* But I've heard of one case where it did and he's driveing a Ford now. Just curious doesn't anyone think that me raising my torson bars an inch effected my mpg?
hmmmm.. As a last resort I wonder how much it would cost to change out to 3.42 or 3.73 gears? |
