Old 03-13-2003, 12:09 AM
Little Burner's Avatar
Little Burner Little Burner is offline
Send a message via AIM to Little Burner
_________
Friends help you move
Real friends help you move body's
~TeaM~MindgamE~
Pic's of my ride
Old 03-13-2003, 04:44 PM
nittanys1's Avatar
nittanys1 nittanys1 is offline
Send a message via AIM to nittanys1
^^^^what kinda vehicle is that???^^^^
Old 03-17-2003, 10:12 PM
ikeu86 ikeu86 is offline
dude cool!!!!
[img]C:\My Documents\Resize of transformer.jpg[/img]
Old 03-19-2003, 12:04 PM
civic98stunna civic98stunna is offline
Here's my interior. Its still a work in progress, and I have more done to it now, but this is a good shot of it:
98 Civic Ex Coupe
Old 03-21-2003, 11:34 AM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
did you do all that yourself? How'd you get the carpet on the door panels and the center console red? Also, step by step, how'd you get the dash done?
Name's David.
Old 03-21-2003, 11:52 AM
Yes I did everything myself. the carpet is just some cloth that I put over the old cloth. I used a little cloth glue to keep it connected to the old cloth, and then i stuffed the edges into the gaps between the armrest and door plastic, so it looks clean. For the dash, I took out everything that was removable, like the vents, the gauges, the center part with the radio/airconditioning, the glovebox, the knee bolster under the steering wheel, EVERYTHING that could be removed. Then I taped off everything that i didn't want to get colored, including the windshield, then i opened the doors and taped them off too. after that, i sprayed some vinyl/plastic prep spray onto the vinyl to dry it out so that it would suck up the dye. after that, I just sprayed the vinyl dye all over the dashboard vinyl until it was all red.
98 Civic Ex Coupe
Old 03-21-2003, 12:20 PM
does anyone know where i can get those kind of dyes? Don't you have to clean the surface too?
Name's David.
Old 03-21-2003, 12:22 PM
also, is there a trick to getting the center console out? I tried a couple weeks ago when i was messing with the shift boot but i couldn't seem to get the whole center console out.
Name's David.
Old 03-21-2003, 12:23 PM
www.g2usa.com is where i got mine. very high quality stuff, but its expensive.
98 Civic Ex Coupe
Old 03-22-2003, 03:13 PM
The center console is easy to remove. there are screws on either side of the center console, both the part with the armrest/e-brake, and the part with the shiftboot. Take out all those screws, slide the e-brake part backwards and up, and then do the same with the shift boot part. Its as easy as that, i could do it for you in two minutes.
98 Civic Ex Coupe
Old 03-22-2003, 04:40 PM
yeah i got the four screws out and i still couldn't get it off. I think i wasn't trying hard enough cause i didn't want to bust anything and i also didn't know that i had to pull it back and up.
Name's David.
Old 03-23-2003, 06:30 PM
zippeay zippeay is offline
Theres also screws under the panel in the middle of the console, its a little square panel that you have to pop off and the screws are under it. if you can't move the part around freely just wiggle it and were ever its solid theres most likely a screw.
Old 03-24-2003, 01:08 AM
are we talking about a 98 civic coupe? on my coupe, there are only screws on the sides of the center console, and no screws anywhere else.
98 Civic Ex Coupe
Old 04-10-2003, 02:25 PM
JuMBoBeaTS's Avatar
JuMBoBeaTS JuMBoBeaTS is offline
Send a message via AIM to JuMBoBeaTS
heres my interior... did it myself when i was bored one day... its not finished... damn skoo takin up all my time...
please dont flame me for havin an auto... i had no choice in that matter...
2000 honda civic EX 2dr black
Turbo Future...
Old 04-10-2003, 04:22 PM
yeah i just want to take out my center console so i can paint it a matching red and cover the carpet with something.
Name's David.
