Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Old 10-03-2009, 09:57 AM   #661
Blackcrow64
Blackcrow64's Avatar
Re: Blackcrow64's Talon TSi AWD Project Progress Thread...
Originally Posted by steviek View Post
hmm my bet is it is an unattached vaccuum hose that runs from the TB. It could be the one to the FPR, or one of them that goes from the Intake manifold. I would check all those nipples first. If you have a stethescope you can listen around in areas that works well.
Checked every nipple on the thing. Even compared it to an extra IM off the car to see if I was overlooking something but nothing. TB is completely sealed unless the gasket is leaking... But the leak is louder than the motor and I don't think the gasket could be leaking that bad but maybe... I might try some RTV on there to see if that makes a difference...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Blackcrow64 is offline   Reply With Quote
Old 10-06-2009, 02:59 PM   #662
Blackcrow64
Found that the IM gasket wasn't flush and had a wrinkle in it which caused the leaks... Also found two missing bolts in the turbo compressor housing... Fixed it all and it runs! Took a few trys but it finally started idling on it's own after adjusting the fuel... Now all I need to do is get a new power steering pump and fix all the awful leaks... Had it run for about 30 minutes with no problems aside from a major leak. Stupid fuel pump lines are leaking horrible right on top of the pump housing. Blah... Stupid cars... But at least it's running!!! =)
Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7C144 Safari/528.16
Old 10-07-2009, 01:34 AM   #663
vanilla gorilla
vanilla gorilla's Avatar
Good job man, glad to hear its running.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
vanilla gorilla is offline   Reply With Quote
Old 10-13-2009, 01:23 AM   #664
Blackcrow64
Ok, so on Sunday I went and worked on this thing again and tore off the intake manifold, throttle body and upper intercooler pipe... Went over everything and found some junk on the IM flange that could have caused a leak. Sanded it all smooth and then used silicone on the gaskets there and on the TB and am hoping that takes care of the vacuum leaks I had... Still gotta solve the fuel pump leak... It is fine at an idle and lower RPM. Once I start to make boost it sprays and leaks like crazy... Also am having an issue with some electronics inside the car... Need to do some rewiring this winter on it. Definitely did a sloppy job on that stuff and need to fix it... Also going to do some undercoat work on it this winter along with suspension and new wheels next spring... Anywho... Hmmm... We'll see what happens where when I go work on it some more. Hoping I can get this fuel pump leak solved. I don't wanna drive it and deprive it of fuel while boosting. Anybody parting out an AWD 2g? I sure could use the fuel pump housing/sending unit...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 10-15-2009, 11:52 PM   #665
ned032002
ned032002's Avatar
The best thing about the winter is that your able to focus on getting all those odds and ends cleaned up that you've been procrastinating about throughout the year. You said the fuel pump is leaking, is it the line that comes right out of the fuel pump or are you talking about the sending unit where it attaches the seal is shot?
ned032002 is offline   Reply With Quote
Old 10-16-2009, 04:23 AM   #666
Blackcrow64
The feed line out the top of the sending unit is leaking where it meets the rubber line. Sprays out all around it... If I can't get it solved I may just run a braided line the whole way from the sending unit to the fuel rail and just use an aftermarket filter rather than the stock one...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 10-16-2009, 08:24 AM   #667
ned032002
ned032002's Avatar
Thats what I was going to suggest. I remember seeing something in the vfaq before that showed how to fix a broken fuel line that goes right through the sending unit. You can get to the sending unit from the back seat can't you?
Old 10-16-2009, 05:41 PM   #668
Blackcrow64
Yes I can. If you happen to come across that article again please hit me up with it. I'm debating a few ways of going about this whole process, none which will be fun or easy. lol...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 10-16-2009, 10:35 PM   #669
ned032002
ned032002's Avatar
This isn't the exact site but the same idea
http://www.3si.org/forum/f1/how-fix-...p-assy-420892/
Old 10-17-2009, 01:08 AM   #670
Blackcrow64
Ah... Yeah, that's exactly what I was gonna do with AN fittings. Was hoping there would be an easier/cheaper way but oh well. I'll just do it right so I know I won't have to worry about it again.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 10-17-2009, 08:02 AM   #671
ned032002
ned032002's Avatar
Yeah that looks like a 1 time deal, once it's done then you don't have to worry about it again.
Old 10-20-2009, 01:47 AM   #672
cantgo2fast
cantgo2fast's Avatar
Ya, i broke that hose as well, a replacement from mitsu is $75 which isnt cheap either
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
cantgo2fast is offline   Reply With Quote
Old 10-20-2009, 06:08 PM   #673
nofear39427
Send a message via Yahoo to nofear39427
Atleast its running now... that car has put you through hell dude.
You just have a few kinks to work out and perhaps everything will be working smoothly
nofear39427 is offline   Reply With Quote
Old 10-20-2009, 09:26 PM   #674
Blackcrow64
Tomorrow is supposed to be 70 and sunny out and I don't have to work! It will definitely be a good day to get things done on it... Hopefully get everything fixed up and drive it as long as the fuel line is done leaking... Will know more once I start it up again and test some things out...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 10-20-2009, 11:15 PM   #675
ned032002
ned032002's Avatar
Good Luck dude, I have high hopes if that gives you any confidence!
Thor's Car Progress Thread: '90 TSI AWD project, parts cars, and the Cavy. 56k death! Thor06 Members Projects 45 10-28-2008 04:26 PM
FS: 1992 Eagle Talon TSi AWD 5 speed mahanian Off-Topic 0 02-04-2003 06:08 PM
Eclipse GSX VS TALON TSI AWD Platinum_Skyline01 Off-Topic 4 10-15-2002 03:49 PM
FOR SALE! 92 talon tsi awd 5 speed brads94accord Off-Topic 0 06-27-2002 02:50 PM
'93 Eagle Talon Tsi AWD Turbo A/T Andre the Giant Off-Topic 0 12-21-2001 02:40 PM
