Old 01-16-2011, 09:58 PM   #46
f40
Smile Re: Ferrari F-40 "Beurlys" spider, scale 1/8
Welcome back. As always awesome work mate.
f40 is offline   Reply With Quote
Old 02-23-2011, 07:22 PM   #47
Pascal D
I was able to put in a lot of work on this project. So here's an update.
A aluminium sheet (2 mm) was used to reinforce the plastic Pocher frame :
Started building the "boxes" that are part of the chassis :
Pascal D is offline   Reply With Quote
Old 02-23-2011, 07:26 PM   #48
Pascal D
Continued with the "boxes" :
Yours sincerely
Pascal
Old 02-24-2011, 07:22 AM   #49
gtziaf
gtziaf's Avatar
Great job...
Your effort to this work are inspiration for us...
I 'm sure, you doing a masterpiece here...
gtziaf is offline   Reply With Quote
Old 02-24-2011, 10:30 AM   #50
f40
Great work . Hard to ever believe you started this project from a Pocher kit.True Craftsmanship.
Old 02-24-2011, 10:41 AM   #51
rx7king
rx7king's Avatar
wow that was quite the update! thanks for showing the refereance pics so we know what your replicating, helped a lot!
rx7king is offline   Reply With Quote
Old 02-24-2011, 04:42 PM   #52
Pascal D
Thanks guys
The "boxes" were not big enough, so I added a 2mm plastic strip :
The front has some difficult angles :
The 2 triangles have been joined with some Lego and a piece of aluminium sheet :
The triangles have to be strong, because they will carry the weight of the front bonnet :
I used a piece of brass square rod, and shaped it like the real ones :
The square rod gave me an idea. How about using it to make the latches on the bonnet ? Like this :
Fits perfectly ! :
Old 02-24-2011, 04:48 PM   #53
Pascal D
The new radiator will be made from plexiglass. The cooling pipes are attached to the triangles on both sides of the radiator. First I made these from plexiglas and covered them with aluminium sheet :
Yours sincerely
Pascal
Old 04-10-2011, 09:37 AM   #54
Pascal D
I wanted to make the radiator from aluminium sheet, here's some pics of the progress :
The fan was a lot of work :
Progress is very slow, but it's going in the right direction.
Old 04-10-2011, 02:24 PM   #55
Scalemodelfanatic
Scalemodelfanatic's Avatar
WOW...magnificent build and detailing!!! The amount of rework and scrachtbuilding to replicate this special F-40 is truly spectacular.
Scalemodelfanatic is offline   Reply With Quote
Old 04-11-2011, 10:25 AM   #56
f40
Just awesome work. Brilliant!!!!
Old 04-16-2011, 06:48 PM   #57
Pascal D
I made the frame for the fan from brass sheet :
The frame that holds the fan has raised edges :
To simulate this, used copper wire :
It took me a couple of hours, but it looks good :
The radiator has a coolant pipe on each side. I made these from 2 pieces of brass tubing soldered together :
Yours sincerely
Pascal
Old 04-17-2011, 03:35 AM   #58
ridefast
ridefast's Avatar
It's really hard to express how much we can learn from builds like this one. Thank you for showing us your great work Pascal. Keep it up.
ridefast is offline   Reply With Quote
Old 04-18-2011, 02:01 PM   #59
CifeNet
CifeNet's Avatar
Very intense and entertaining!
-- CifeNet
CifeNet is offline   Reply With Quote
