#46
Re: LIM gasket
yea I cleaned up well, and plus my engine looks like new, compare to some pictures I've seen here.
and I put enough gooh, I dont think I goo-d them up too much though! you think that might of been the problem? do I have to re-buy the other stuff too? |
#47
Re: LIM gasket
like the coolant elbows, s/c gasket, 2 o-rings?
also, when I re do it, can I put rtv sealant on the bottom of the end seals? or just the corners? |
#48
Re: LIM gasket
As long the coolant elbow does not break you do not need to replace it again. I would think that the o-rings on the supercharger would not need to be replaced again.
#49
Re: LIM gasket
If the car hasn't been ran for very long and the supercharger gasket comes off ok, you should be good there too.
Not sure what I would do on the LIM gaskets. BTW, what torque did you use on the LIM bolts?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
#50
Re: LIM gasket
For the cost I'd replace the LIM gaskets with the FelPro brand. It should be under $50. Also, it would be a good idea to take the LIM to an auto machine shop and make sure it is true or not warped which does happen.
#51
Re: LIM gasket
ok, Ill be shoping around locally for the felpro rubber gaskets.
But I torque'd the bolts as follows, like u guys told me too. LIM 11 ft/lbs S/C 17 ft/lbs Tensioner 37 ft/lbs |
#52
Re: LIM gasket
Torque specs look good, you did tighten in sequence, right?
I dont know what to tell ya. Are you sure the valley gaskets are in the right direction? (Refir to the pictures in this post) Both Bob and I used the felpro set although the GM set shouldnt be much different. http://www.automotiveforums.com/vbul...d.php?t=936863
#53
Re: LIM gasket
Whats up guys.
Yes I did tighten them in sequence, and Im going to start putting it apart today, and see how the valley strips look. From what it looks now, seems that the one thats leaking might of moved. Oh, well lets hit it for the firm...... and I will make sure I "gooh" up the corners with blak rtv! I will keep you guys updated. |
#54
Re: LIM gasket
I just finished taking it apart and looks like there wasnt enough rtv sealant on the driver side valley strip, under the throttle body.
Uhmmmm, I guess I'll be gooin' it up this time... |
#55
Re: LIM gasket
Just finished up putting the GTP back together, took the GM aluminum gaskets off and replaced them with Felpro's.
all I need is the PCV yellow rubber o-ring! Is this something I can buy separate or do I have to buy the whole pcv? |
#56
Re: LIM gasket
You had to remove the PCV Valve from the supercharger?
You should just be able to go to the dealership and buy a new O-Ring. Might as well replace the PCV Valve while you have it out.
#57
Re: LIM gasket
Question guys. That yellow o-ring im talking about, it is from the pcv valve isnt it?
I went to autozone and they showed me a regular looking pcv valve and the one on top of my supercharger has three hoses going to it! What is that then? |
#58
Re: LIM gasket
There should be two yellow O-rings, they go on top of the LIM, under the supercharger. They flow coolant to your throttle body.
#59
Re: LIM gasket
hey tblake,
The part im talking about is called " manifold vaccum seal" according the a tech at gillespie pontiac in chicago. and what I need is the o-ring for it. but unfortunetly they didnt stock it, and I needed my car. so I went to autozone and bought myself an o-ring kit, and found one that was snug for that piece. and it worked. This piece sits piece sits on top of the supercharger wich has three ports, and I know the big hose goes by the master cylinder. All im hoping for it now, is to not leak! Wish me luck. |
#60
Re: LIM gasket
Ahh, yeah I know what your talking about now.
Good Luck! I'm sure you'll be fine! BTW, My LIM gasket has been leaking since january/february, and friday its supposed to be nice here, so I'll probably get it changed. I did order the metal framed gaskets from GM, so I hope they do alright for me.
