Old 08-13-2001, 05:55 PM
primera man's Avatar
"P-Man"
I have never struck this problem before
Only thing i can think off is, did you shake the can really really well ?
Or maybe i'm guessing the paint is to heavy when you are applying it.
View All My Models Here.
Old 08-13-2001, 06:08 PM
Guiddy's Avatar
Guiddy Guiddy is offline
Originally posted by JE123
Today I painted my Pontiac Firebird Ram-Air. While I was spray painting it I noticed there were little bubbles in the paint. So I stripped all of the paint off. By the way this is the second time I had to strip the paint off of this particular model. Does anyone know what the bubbles could be caused from? Before I put the paint on I primered the body. So I don't know if that is what caused it.
What were you painting it with? Did you primer it first?
What did you do immediately before applying that paint?
We can get to the bottom of this, and I have had that problem before.
Give me some help, and we can narrow it down!
Old 08-13-2001, 11:13 PM
JE123's Avatar
JE123 JE123 is offline
I was painting with spray paint (Boyds Grape Pearl) and yes I primered it the day before. Before I put the spray paint on I just wiped any fibers off of the model. I am beginning to think that maybe it was the paint reacting with the primer. But I don't know.
Old 08-14-2001, 03:00 AM
Guiddy's Avatar
Before I put the spray paint on I just wiped any fibers off of the model...
WIth a wet cloth or dry?
Old 08-14-2001, 04:00 AM
"P-Man"
guiddy......i still think that the paint is being sprayed on to thick and to close. The air from the can is sraying to hard onto the model.
I had a play this afternoon on a old body shell and i was starting to get little bubbles in the paint (along with runs )
Old 08-14-2001, 04:17 AM
Guiddy's Avatar
Yeah, the runs would signify that! He didn't mention runs though, which leads me to think it may be lack of shaking, or dampness under the paint which escapes through bubbles!
Sometimes I get bubbles at the end of a can, especilally white!
Old 08-14-2001, 04:21 AM
"P-Man"
The couple of bubbles i did get i pricked them straight away with a needle and the paint then just bleeded into the rest and you could not see it.
Not a good idea if you have heaps of them
Old 08-14-2001, 05:44 AM
Guiddy's Avatar
He'll just have to let it dry and then get that 1200 wet and dry out! Flat it off, leave for 24 hours and try again...
Old 08-14-2001, 11:57 AM
JE123's Avatar
I just used my hand to wipe off any fibers.
Old 08-14-2001, 12:48 PM
Guiddy's Avatar
OK, I would go with the not enough shaking/low on paint solution or too heavy a coat like Warren said?
Old 08-14-2001, 04:45 PM
JE123's Avatar
How many coats of paint do you usually put on a model? On your first coat do you cover everything or just lightly cover most of the areas? Do you primer every piece in a model (exept the windshield and lense)?
Old 08-14-2001, 04:56 PM
Guiddy's Avatar
Always at least 4 coats on solid colours, about 3 if I am using a Basecoat/Lacquer
On your first coat do you cover everything or just lightly cover most of the areas? Do you primer every piece in a model (exept the windshield and lense)? [/b]
First coat pretty light, but even coverage. Light orange peel look!
Yep, everything is primered! Even if you then brush paint over it, it adheres and looks better!
Old 08-14-2001, 04:58 PM
Jay! Jay! is offline
Horizontally Opposed
I tend to cheat a bit and skip the priming on suspension parts if they're just going to be black. So far, so good.
Hierarchy of Subaru:
(Click to see mine!)
Old 08-14-2001, 05:01 PM
Guiddy's Avatar
Tut Tut!
Old 08-14-2001, 05:47 PM
JE123's Avatar
On the first coat should you still be able to see the white or whatever the plastic is molded in? And what is orange peel? Do you suggest Krylon Primer?
