Old 01-22-2006, 03:24 PM
Samurai75007 Samurai75007 is offline
Re: 360 Cs Blu Notte
Lookin good so far...
Old 01-22-2006, 04:29 PM
blubaja's Avatar
blubaja blubaja is offline
Good gosh!!! How did I miss this thread?!? This looks freakin awsome man!!! I love how you are changing the bodywork and seats. Color combos are great too. Nice to see Ferraris in colors other than red. Keep up the great progress man!
Old 01-22-2006, 05:07 PM
Captain Mark's Avatar
Captain Mark Captain Mark is offline
Good work! Nice creativity.
Old 01-22-2006, 06:19 PM
klutz_100's Avatar
Looks great Gio, but haven't you put them on upside down?
Old 01-23-2006, 04:02 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
you've good memory
gio
Old 01-23-2006, 04:42 AM
GvEman's Avatar
GvEman GvEman is offline
Awesome! Very nice looking ferrari!
Best Regards
Anton
Old 01-23-2006, 06:10 AM
alakai's Avatar
alakai alakai is offline
Send a message via AIM to alakai Send a message via Yahoo to alakai
That paint is jaw-dropping beautiful.
Old 02-27-2006, 05:22 PM
gionc's Avatar
Authorized Vendor
Quetly slow project.. well some few updates, I'm waiting TS13 cure perfecly to polish all so.. I make some practice with my new toy:
new alu shocks, oil filter, liquid reservoirs, ecc. ; also I post the same image on the mill/cnc group discussion thread.
oil filter turned and milled (MPWR thanks for your f40 inspiring thread) and pulleyes
just for reference the textile in the background is a smooth mouse-pad, imagine the scale factor
well I'm working on the dashboard, just a couple of days ans I'll post something, thanks all for comments
ciao
giovanni
gio
Old 02-28-2006, 04:17 AM
klutz_100's Avatar
Great stuff Gio!
Seems you form a good working relationship with your lathe pretty quickly
Old 03-09-2006, 07:27 PM
calvin3's Avatar
calvin3 calvin3 is offline
Amazing paint job.....I could only dream to paint that good.
Old 03-09-2006, 09:39 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Terrific work, Gio! Those dampers and oil reservoirs are awesome. (May have to try that myself!) The small diameters on the dampers are particularly impressive.
PHOTOBUCKET SUCKS
Old 04-09-2006, 06:12 PM
gionc's Avatar
Authorized Vendor
Hey folks: some few updates and.. thanks all for your kind comments
So far some engine's job on that V8:
Looks like I done a "copy&paste" from the MPWR's TT thread, is right, thanks a lot my friend for this tip, but seem i need to try a couple time more to have a decent result
1- ferrari PE brand on the clean airbox, glued with a bit of CA
2- I steal those applicators from my dentist , I find out now to my LHS, not cheap at least
3- tamiya white primer trought airbrush (I become to enjoy my new Iwata HP-CS, great- primer decanted from the can)
I gently scratch out he paint from the PE part
Do you mean when you shake a Coke can, Prosecco or Champagne? Well nothing like a little decanting jar, when you try to open.... SWWWWWWWWAMMM ink everywhere also after a couple of days
Well: I spray a flat "Insigna red" over the primer, I put down the compressor's pressure and mix a thick paint to do some texture, after paint's curing I rescratch the paint from the PE with a sharp cutter
This is the not-detailed engine: primed in gloss black than sprayed with AlcladII Polished Aluminium, washed after a couple days with acrylic flat black
gio
Old 04-09-2006, 06:31 PM
gionc's Avatar
Authorized Vendor
Some other work on interiors:
I had to clone my own modyfied seats:
1- The clay's base for the silicon mold
2- The 2 shells mold
3-first few casted pieces: I had to correct some trouble doe to the thin seat's size in the half: so I had to do some "by-pass" symply cutting the silicone molds, last 2 parts (nr.4) should be ok but needs a lot of cleaning
4- a cleaned and just casted seat
5- primed parts
6- pre-shaded parts (with citadel acrilics-brown)
7- 1 hand of flesh (citadel)
well looks like I have some work to do on this leather but I can see the way: an anticipation: I want the seam! stay tuned.
gio
Old 04-09-2006, 06:46 PM
gionc's Avatar
Authorized Vendor
So far some job on the dashboard:
nothing new, all was explained from Alex Kustow in his thread and from Alessandro Prini in his one: the only difference is that I tried the "styrene way" insthead the "putty way" , so I have some chances to have a sharp place for the climas command w/out mill anything (almost anything)
I cut out the clima and fill the new shape with styrene, than I fill with 2p.putty and finished with putty
Well, soon with this part finishing: I design some PE parts for vents (I need a couple weeks to etch in a service):
gio
Old 04-09-2006, 06:53 PM
gionc's Avatar
Authorized Vendor
This system's performances are every day worst: it need 3-4 time to post.
Well, finally some body works:
body shell clearcoated with TS13 trought can, several thin coats followed from a couple of "almost wet" coats: quetly an appreciable orange peel as ever.
I cut down rought peel with 2000 followed to 4000 grit and polished a couple times with 3-step compounds, then waxed, not bad to me, better at naked eye
Thanks a lot everyone!
gio
